fj40 snorkel question??
Discussion in '40- & 55-Series Tech' started by 74cruiserintexas, Jan 14, 2003.
  1. 74cruiserintexas
    74cruiserintexas
    37
    Dec 24, 2002
    I am wanting a snorkel for my 74 fj40 with F motor. My question is.... &nbsp:Do the snorkels use the existing air cleaner assembly or do the snorkels come with a new air cleaner integrated into them?
  2. Guest
    Guest Guest
    I'M IN THE PROCESS OF MAKING ONE. CHECK SOME TECH SITES AND JUST MAKE ONE.
  3. 74cruzah
    74cruzah
    38
    2
    May 20, 2002
    If you are using a safari snorkel you can make it work. It comes with a lot more hose than you need, and you will need to modify the inlet end of the airbox and clamp it down tight. not a big deal. Hardest part for me was cutting into the metal for the first time. Oh, you will also need to relocate a couple of things a little lower on your inner wheel well in order to make room for the snorkel.
  4. darkman
    darkman
    91
    1
    Jul 22, 2002
    Hello:
    I think that you will find that any snorkle that you purchase will be quite expensive and will require a considerable amount of modification in order to make it work and look good.
    A home made snorkle will be much less expensive and is exptemely easy to make. Mine is made from light-weight seamless pipe, a Tracel intake hose, a lenght of rad hose from a detriot diesel engine and the top off the intake from an old air compressor. Including the pipe bending, this snorkel cost me about $22.
    It actually looks and works excellent .... email me if you would like a picture at adsum30@hotmail.com
    Mike
  5. 74cruiserintexas
    74cruiserintexas
    37
    Dec 24, 2002
    That snorkel does look good. I am a metal man myself, so I could get some 3 inch light weight steel pipe and mandrel bend it and have an all steel unit. I am also thinking about finding an air filter box off a tractor that uses the very large air filters and can be located anywhere that you want.
  6. bjowett
    bjowett Supporting Vendor
    3,051
    543
    Oct 28, 2002
    Western Massachusetts
