FJ40 overdrive unit
Discussion in '40- & 55-Series Tech' started by John Greene, Nov 14, 2007.
  1. John Greene
    John Greene
    6
    Nov 11, 2007
    I would drive my 1978 FJ40 more (don't have 40,00 miles on it yet) if it wasn't so wound up at 50 mph. I have thought about installing one of the "overdrive units" available on the aftermarket. Has anyone done this that could give me some results they realized? What does it do to rpm's at 50-55 mph. Has anyone checked miles per gallon on the road with one of these units?
  2. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    The overdrive units are not worth pursuing. Do a search for "fairey od" or some variation.
    You have three viable options- larger tires, smaller (numerical) ring and pinion ratio, or an overdrive transmission. In your case the H55 from Toyota would be the easiest to install. It is still available new from Toyota.
    Many people would be willing to trade their 3.70 ratio third members out of 79-83 FJ40's and all FJ60's for the desirable fine spline 4.11 ratio gears in your truck.
  3. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    3.70 gear ratio would drop your RPM's from about 2900 @ 65 mph to about 2600, assuming 31" tires.
  4. Fast Eddy
    Fast Eddy SILVER Star
    14,186
    1,618
    Apr 5, 2006
    Morgan Hill, CA
    Stock sized tires? How about some rubber overdrive? 10% is easy.
  5. Jetboy
    Jetboy
    1,240
    43
    Sep 16, 2004
    I'd vote for tires too. Something like a 33/9.5 can make a pretty significand difference in cruising ability. I'd probably go with a h41 and taller tires rather than an h55. That's just my opinion though, because I'd use the low gearing as much or more than the 5th gear. I'd guess either tranny is cheaper than an old bolt on over drive and probably more efficient. Less gears to spin before you get to the ground.
    THink about it this way; the slower you drive, the more time you get to enjoy driving a cruiser...
  6. DiHrdBowTi
    DiHrdBowTi
    123
    Jan 7, 2006
    Reno
    I have the Ranger overdrive in front of my stock toy 4 speed but then I'm also running a 350. I like it.
  7. Advent
    Advent
    549
    1
    Sep 3, 2004
    Juneau, AK
    I've actually got a Fairey overdrive that supposedly only has 15,000 miles on it that came out of a '78 (supposedly) FJ55 that I'm not using. Plans changed, but it appears to be fine.
    I think a lot of people's problem with them relates to not keeping them properly lubricated and tightened.
    They're sure as heck a lot cheaper than new gears or an H55F. For that matter, cheaper than a new set of tires. Not hard to install at all.
  8. brider
    brider
    609
    Feb 9, 2005
    I just installed a Fairey on my Pig that came off a '78 FJ40. Works great.
    Taller tires is easy, but affects your crawl ratio. So do 3.70 axles.
  9. Living in the Past
    Living in the Past SILVER Star
    12,000
    775
    Apr 21, 2005
    X2 you have to loss something to gain something. The H55F is a good tranny but longer than the H42 making a short rear drive line even shorter. With an overdrive you don't loss anything but your four speed now gives a overdrive plus eight forward gears in both high and low ranges.
    Jim
  10. Hltoppr
    Hltoppr SILVER Star
    2,023
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    My troopy has a fairey overdrive in it, and it really makes a difference in town. The original H41 (5:1 1st) is pretty low and even starting in second runs through the gears pretty fast when not in overdrive....
    The overdrive just makes it much more comfortable on the street...
    -H-
  11. 1962fj40
    1962fj40
    143
    3
    Jul 1, 2004
    Phoenix, AZ
    Just caught this older post. Does anyone now where I may find a Fairey OD??
    Robert
  12. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    There is a Mudder that posted that he had eight Fairey OD units. I'm sorry that I don't remember who it was, but maybe they'll chime in.
    Ed
  13. grant5127
    grant5127
    5,025
    11
    Oct 31, 2003
    Meridian,TEXAS
    Nice novlety....
    Has not been made for what, almost twenty years??
    Not aware of anyone providing product support for this toy...
    Save your money and purchase a Toyota five speed transmission...
  14. Combat Chuck
    Combat Chuck
    2,936
    3
    Sep 16, 2008
    Freensville
    H55 will mate up niecely to an F engie, and save you money on adapters. If you go aftermarket OD, or get a new tranny you'll have to move the T-case bracket back, and have the drive shafts adjusted.
  15. ranger
    ranger
    1,153
    2
    Jan 18, 2003
    Mountain Hole, Idaho
    I believe they still make them for Rovers under Superwinch. Not for TLC though.
    Finding parts is not easy as well.
