FJ40 minitruck front disk conversion issue - HELP!
Discussion in '40- & 55-Series Tech' started by AV-FJ, Mar 4, 2003.
  1. AV-FJ
    AV-FJ
    4
    Mar 4, 2003
    I did a disk brake conversion on my FJ40 using all '85 Toyota minitruck parts including the locking hubs. The only problem is that I can not seem to pull the birfield out far enough to get the clip on that goes on the very end of the birfield on the inside of the locking hub. Is this a problem anybody has encountered? Will I have problems if I run it without the clip?
    Thanks for any help or ideas you can offer!
  2. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    Re: FJ40 minitruck front disk conversion issue - H
    Are you talking about the C-clip in the hub? If so, YES you need it, and i had kinda the same problem with stock hubs, just work at it
  3. AV-FJ
    AV-FJ
    4
    Mar 4, 2003
    Yes, the c-clip in the hub.
  4. woody
    woody Internet Fireman Staff Member
    10,331
    Media:
    303
    1,087
    Jan 15, 2002
    Toquerville UT
    question...what birfields, what spindles, what lockouts?
    yes, the clip is required, but some variations used a bolt/fender washer.
  5. AV-FJ
    AV-FJ
    4
    Mar 4, 2003
    These were all parts that I pulled off of the same axle from an '85 4x4 minitruck.
  6. woody
    10,331
    Media:
    303
    1,087
    Jan 15, 2002
    Toquerville UT
    then it should work...might need to thread a bolt into the end of the birf with a piece of flat iron as a washer and give 'er a yank to pull it out enuf.
  7. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    I had to use the bolt and washer with mine. The Birfield did not come out far enough in the hub to puyt the clip on.
    BTW I do have Warnd hubs. That may be the difference.
  8. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    I seem to recall on my 84 mini truck that it used the bolt and fender washer arrangement. It originally had the auto locking hubs that I switched out to manual hubs after ~ 10-12 years of use. The 85 should be the same arrangement.
  9. AV-FJ
    AV-FJ
    4
    Mar 4, 2003
    Assuming I go with the bolt and fender washer (this may have been what came on it anyway...I honestly cant remember) is there anything special I would need to know? Can I assume that the diameter of the washer should be slightly bigger than that of the shaft?
    Thanks for all the help!
  10. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    AV-FJ, did you use new seals, etc.? Check your axle retainer / dust seal (part #31 in the pic below) isn't keeping the wheel hub from sliding all the way in. Happened to me and others.
    [​IMG]
    Dave
  11. toddslater
    1,498
    2
    Oct 31, 2002
    Kennett Square
    I pulled out my 79 to 90 Haynes mini truck book to look at the front hub xploded views. The auto locking hubs have the bolt and washer arrangement, the manual hubs are shown with the snap ring. What I can't remember off hand is whether or not I had to retain the bolt and washer arrangement when I converted the auto locks over to the manual locks. I am thinking that I did. I can pull the hub and check it out tomorrow night. Hmmm, somewhere in the basement are the auto locking hubs I pulled out....if I didn't reuse the bolt and washer, it'll be with those hubs...probably quicker to pull the hub vs. trying to find my old stuff.
  12. Guest
    Guest Guest
    "Did you use the original hubs off the drum brakes? If so this is your mistake as the mini truck units are shorter hubs.
  13. SpaceGhost
    SpaceGhost
    467
    1
    Feb 1, 2002
    Indianapolis, Indiana
    Did you use the mini birfs also? If you used all the parts, knuckles out and birfs on your inner axles the clip will fit. Thread a bolt in the end of the birf and pull it out, while installing the clip.
  14. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    What Spaceghost said and get a good pair of c-clip pliers. It's too much of a pain to deal with the two screwdriver method when you're having fitment problems. Then the pliers go in your trail tool kit 'cause that's where you will appreciate having them. I just got a pair of craftsman "e-clip" pliers for $6 on clearance that work better than my snap-on snap ring multi-adjustable POS.
