FJ 80 Long Range Fuel Tank
Discussion in '80-Series Tech' started by campoj2, Jun 13, 2008.
  1. campoj2
    campoj2
    1,085
    1
    Dec 27, 2006
    The Land of Frank Rizzo
    Does anyone sell a simple long range fuel tank for the 80? I don't want an aux tank, I just want a larger capacity fuel tank to replae my OEM unit.
    Ideas?
  2. Atoyot1031
    Atoyot1031
    2,122
    11
    Nov 16, 2006
    Aspen, CO
    I suppose you could rig up the long ranger as a main, but it's easier to setup as an auxillary. It also boosts your capacity to near 70 gallons!:eek:
  3. jfz80
    jfz80 bound to cover just a little more ground
    7,389
    Media:
    3
    1,989
    Jun 5, 2005
    High Point NC
    Man a Fre sells them but they only order batches every 2-3 months and units are presold. 38 gal tank for stock location. You can look i my current leaky gas tank thread and see other manufactures but they are all from across the pond. Call Man a fre and they can quote you a price as its not listed on their site.
  4. campoj2
    campoj2
    1,085
    1
    Dec 27, 2006
    Thanks jfz80 & 1031. I am a big a plug and play fan, and the idea of having 2 tanks or 1 big one, I would prefer to just hang one tank.
    I'll call Fre on Monday.
  5. grunt001
    grunt001
    57
    Sep 19, 2007
    You may want to do some more searching on that 38 gallon replacement tank (not the aux tank) before making a leap. I heard some folks love it, but it is not without issues.
    Issues I've read about here include:
    1) makes some type of "burbing" "gurgling" noise (sounds strange, but that's what I've read here on MUD)
    2) you lose some clearance (it hangs like 2 inches or so lower than the frame rails)
    3) it's a non-trivial install; again, based on what I read here.
    So, not saying don't get it. Just saying read up before you leap.
  6. grunt001
    grunt001
    57
    Sep 19, 2007
  7. SWCruiser
    SWCruiser
    628
    28
    Jun 19, 2004
    NY and AZ
    check it out first
    Not trying to be negative, but you should really check out the 38 gallon tank before opting for it over a subtank.. The subtank install is not really that difficult and I believe the cost difference between the two is negligible. I saw the 38 gallon tank and much preferred a subtank. MAF also sells subtanks in 24 and 34 gallon IIRC.
  8. kup99
    kup99
    1,046
    Sep 30, 2006
    Calgary Alberta Canada
    Make sure they pressure test the tank... mine is from Man a Fre and it had a leak.... they only warranty the tank for 3 months, so i had to have it welded by another shop!!..... this left me with a bad taste in my mouth, but it's just my 2 cents!!
  9. campoj2
    campoj2
    1,085
    1
    Dec 27, 2006
    Thanks for all of the input, it is invaluable.
    As for the install of the aux tank, I think it is as complicated as it gets, did you read Elmanchari's write up? Between the finding a filler neck, installing the switches, plumbing and the wiring it seems to be a little deep for the novice. I'm looking for something a little more easy to install without all of the associated pain.
    It looks like there are 2 issues with this tank, the first is that it hangs a little low and and the second issue is that you have to mod the fuel pump. As for the burping, I have been known to burb and pass a little gas on occasion and if my 80 wants to do it, I don't have a problem with it. So long as I don't look like a Roman Candle when it burps everything will be OK.
  10. nicholas
    nicholas
    2,598
    Media:
    5
    11
    Jun 9, 2006
    N. Nevada
    I too would like a little more fuel capacity without too complicated of an install.
  11. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    MAF was supposed to talk to the manufacturer of the larger main tank and ask them to install some baffles to mitigate to burping issue. Whether this ever happened I don’t know. The larger tank comes with new strap hangers; one of which requires locating and drilling a hole in the back floor for a plate/stud bracket. I can’t remember if the second row seats are supposed to come out or not as mine never had any.
    Keep in mind the expense of buying this tank, removing the stock tank, extending the fuel pump bracket, wires, fuel pump hose, extending the fuel level float, low fuel warning, removing seats and carpet, drilling the floor, etc, etc, gains 13 gallons more than the stock tank. Just trying to say its not exactly a direct bolt in.
    Bill
  12. campoj2
    campoj2
    1,085
    1
    Dec 27, 2006
    I crunched the numbers last night on fuel.
    On any given day you can safely use 20 out of 24 or 34 out of 38 gallons, I like a little cushion. On perfectly flat terrain you are lucky if you can go 60 miles on 4 gallons (ironically in my TDI 4 gallons is about 200 miles!)
    20 x 15mpg = 300 miles
    34 x 15mpg = 510 miles
    On a recent trip to the Outer Banks, I average 15 on the road, when I got into the sand the mileage went to the basement.
    I'm not sure if the big tank is way to go, also you are going to have to factor in the cost of a suspension adjustment as well.
  13. SWCruiser
    SWCruiser
    628
    28
    Jun 19, 2004
    NY and AZ
    Campoj,
    Take a look at Romer's install. He did a great job of going over what is required. El mariachi did a great job as well but he was trying to trying to go the route of using the original subtank computer. This definately made it more complicated. Without inclusion of this all the other stuff is straightforward. If I wasn't going to keep my spare under the truck I would have looked at the 24 gallon sub fuel that MAF sells. Then you would have
  14. campoj2
    campoj2
    1,085
    1
    Dec 27, 2006
    I'll research Romers write up, El Mariachi's install was doctorate/thesis level work, something I am not going to get into.
  15. matt49
    matt49
    426
    2
    Jun 4, 2007
    CANADA
    :grinpimp: or u guys could spend a week in golden and have christo and joe install it...lol.....just got back from getting mine done....100% OEM MAIN TANK, SUB TANK, OVERHEAD CONSOLE, AND WIRING
  16. ARussell
    ARussell
    48
    Jun 16, 2008
    Newbury Park, CA
    I had the 38gal man-a-fre replacement tank installed and it originally made noise and sounded like it moved around a little. Eventually wrapped the straps and any metal2metal surfaces with flat rubber and it has been trouble free since.
  17. Nay
    Nay
    4,323
    32
    Aug 17, 2004
    Colorado
    I've decided to just go to the gas station after reading these threads :flipoff2:
  18. 1shot1kill
    1shot1kill
    875
    150
    Sep 30, 2005
    NW
    15 mpg!:flipoff2:
  19. NLXTACY
    NLXTACY Wits' End Supporting Vendor
    18,306
    Media:
    23
    6,380
    Dec 7, 2007
    West Hills, CA
    Ok don't tease, what did this set you back?
  20. Clarkie
    Clarkie
    22
    Jun 12, 2008
    Perth Australia
    if you have a look on the aussie arb and opposite lock web sites they have larger OEM and AUX tanks but you will have to import it!
