firewall pass-through wiring harness connector
Discussion in '40- & 55-Series Tech' started by rusmannx, Apr 12, 2010.
  1. rusmannx
    rusmannx
    1,139
    4
    Feb 9, 2002
    HIT IT!
    I'm going to be helping a friend with his wiring harness install this summer and I had this thought:
    Wouldn't it be great if someone makes a wiring connector which can be bolted over a hole in the firewall, which the harness inside the body would plug into from the inside, and the harness in the engine bay would plug into from the outside.
    The only real function I can see for it would be to make it easier if you ever had to remove the body from the frame. I have checked out Weather Pack Connectors (it's the only brand I know of) and they do not make such a thing. Anyone know of such a connector?
  2. DanS HJ-45
    DanS HJ-45 SILVER Star
    4,929
    649
    Apr 26, 2007
    Idaho Springs, CO
    You mean like this:
    [​IMG]
    McMaster-Carr carries them. They are also commonly used on airplanes. You can order them from Aircraft Spruce and Specialty as well, or you could maybe get some from an aircraft salvage yard.
    You solder the wires to each connector, and one connector goes through the bulkhead (firewall) and it attached to it.
    They are very nice. I have also seen them on heavy trucks (notably International trucks--often used as school busses).
    Dan
  3. crushr
    crushr
    882
    2
    Apr 12, 2006
    Concord, CA
    Amphenol makes a broad variety - very common in military applications. Search for "bulkhead connector". Seems overkill for a cruiser, tho.
  4. MoCoNative
    MoCoNative
    1,227
    75
    Dec 29, 2005
    Craig, CO
    I've seen that on late 80's Dodge Trucks, seemed to be another plug to get corrosion in it. Except instead of effecting one system, it potentally corroded every wire going into the engine bay.
    The military and aviation grade stuff is best, but kind of over kill.
  5. SouthBostonFJ40
    SouthBostonFJ40 SILVER Star
    6,802
    Media:
    21
    392
    Aug 9, 2007
    Reading, MA
    The type you want is a rack mount receptacle or a bulkhead.
    I sell military cable assemblies. If you come up with a part number, PM me and I will see if I have it or can get it. Very often the price for one connector is around $100 and can get them for between $20 and $30 depending on the connector.
  6. rusmannx
    rusmannx
    1,139
    4
    Feb 9, 2002
    HIT IT!
  7. BDelling
    BDelling
    132
    Aug 12, 2007
    Colorado Springs, Colorado
    American Autowire sells connectors for this purpose. They sell ones with different contact amounts for various needs (10, 12, 20, etc). I plan on using them with I do my rewire this summer.
  8. cruiserbrett
    cruiserbrett Moderator
    2,397
    24
    Feb 19, 2002
    San Diego
    deutsch makes nice ones.
    look here
  9. SouthBostonFJ40
    6,802
    Media:
    21
    392
    Aug 9, 2007
    Reading, MA
    Ladd is a distributor for Duetsch and they might sample you one for free if you ask.
  10. rusmannx
    rusmannx
    1,139
    4
    Feb 9, 2002
    HIT IT!
