Went to Boggin Bunnell yesterday and had tons of fun, then broke on the way back. I was on i 95 almost back to Daytona Beach where I'm at school and had to pull of the he road as my front left brakes started smoking! I'm glad I didn't try to make it to the next exit because my brakes were 95% gone. I had the petal to the floor and took about a quarter mile to slow down. Power steering fluid was everywhere and the front left rotor and hub were stupid hot (obviously). We had tons of bottled water which I dumped all over the rotor and caliper which basically all steamed off. The wheel turned freely so I knew the caliper wasn't seized, so I figure the power steering fluid was making everything hot? It was spraying all over it from one of the high pressure hoses.
So I wrapped the hose to try and just cause the fluid to drip down since I had fluid with me to limp back to Embry Riddle. But then when we went to set off the transmission was slipping extremely bad so I checked the fluid and it was almost all gone.
AAA it is so I accepted defeat and had it towed to a shop the tow truck driver recommended (not AAA recommended), called South Daytona Automotive and there Jack sits...
I have a feeling the transmission fluid was just leaking slowly and I hadn't checked it in the while so I can hold off on that and that all it needs is a new hose. Do you guys think the power steering was the whole reason for the brake failure? The brake fluid was normal...
