Fender flare question
Discussion in '80-Series Tech' started by Guest, Jun 6, 2003.
  1. Guest
    Guest Guest
    Can the rubber strip between the body and flare be replaced without removing the flare?
    thanks
    doug
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
  3. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    Removal is fairly easy though. &nbsp:Don't sweat it.
  4. Guest
    Guest Guest
    OK 2 MORE Q'S THEN......
    (1)there is an approximate 4 inch or so wide strip at the bottom(rocker area)that has a textured finish....and i wonder how that finish is put on? tape? or paint additive? anybody?
    (2)concerning above question,could this be applied to the flares or is a rhino type better?
    reasoning is i have a big scratch in the front drivers flare and a peeling rubber strip on the drivers rear flare and if i gotta take em off to replace the rubber strips i might as well have the scratch fixed ie:get em painted and i thought "now is a good time to try the rhino or textured finish instead of trying to make it match 7 year old paint"
    problem is its hard to find a "good" recommended rhino applier locally(so far anyway)so i thought about the texture on the rockers........
    doug(just hashing out some options)
  5. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    That is a textured "rock guard" that is sprayed on and then painted over. If you want a textured finish you would probably be better served by the bedliner stuff. It would probably be cheaper as well. Also, if you take a nice chunk out of it you won't see the underlying color.
  6. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    If you dont have a rhino or line-x dealer in your area try Duplicolor's spray on bedliner. Christo turned me onto it and its great stuff. Its much less expensive than Line-x or Rhino, easy to get good texture with, and you can pick it up at Autozone, Walmart, etc.
  7. scottm
    scottm
    3,140
    Media:
    8
    851
    Mar 27, 2003
    Third Coast, USA
    I just saw Herculiner at Tractor Supply, the example strip looked nice, thick textured. The kit comes with a small sponge roller and quart, should be perfect. I talked with Line-X, they can't tape off the car and paint in place, taking flares off is a lot of work I've heard. $103/gal, $31/qt, didn't get the price on the kit.
  8. scottm
    scottm
    3,140
    Media:
    8
    851
    Mar 27, 2003
    Third Coast, USA
    Herculiner's website shows it in red & gray also, my truck is gray, hmm.
  9. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    In my experience spray on turns out much better than roll on.
  10. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Friend of mines got a herculined tub he did himself, looks quite good. However, on a curved surface such as the fender flare, I would go with what Keep did.
