Got fans? We've had a lot of calls in the past year for replacement plastic fan blades for your Land Cruisers. Fan blades crack, get brittle or could simply benefit from a shiny new fan. If you're replacing a radiator, belts, fan clutch or a water pump, give your fan blade a look over. We've got AISIN (oe Toyota supplier), OEM Toyota and import aftermarket options in stock for your 2F, 3F, 1FZ, 1HZ, 1HD, 2H, B, 2B, 3B, 12HT or 13BT power plant. Give just a shout or email us at the shop (801-563-1277 or www.cruiseroutfitters.com) if you're in need of a new fan blade.
