factory running board lengths???
Discussion in '40- & 55-Series Tech' started by cajunqueen, Mar 7, 2003.
  1. cajunqueen
    cajunqueen
    121
    Jan 30, 2003
    Was there a difference in the length of the factory running boards on the earlier models and the late models? Mine are on a '63 and they only come to about the middle of the door but I was talking to a friend with a '66 and she swears hers come almost all the way to the back of the door. I'm confused. These are both fj-40's the tubs should be exactly the same. Any thoughts?
  2. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    Mine are stock for a '66 and they are 33 1/2" long. I've got the diamond treadplare covers on mine so they are probably 1/2" shorter in the pure stock form. I love the old "heavy metal" cruisers.
    Ed
  3. northernfj40
    northernfj40
    15
    Dec 30, 2002
    I just run out and checked mine. I pulled mine off to do the tube. Mine is a 67 the boards are stock they are 33.5", about 10" ahead of the wheel well and 6" ahead of the back of the door. :D
  4. FJ_MONSTER
    FJ_MONSTER
    102
    Dec 13, 2002
    THE ONES I HAVE ARE 33 1/2" LONG
    IF THAT HELPS ANY
  5. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    We're all in agreement here, can you believe it???? ;)
  6. Guest
    Guest Guest
    You are correct. There are basically two different lengths. The '63 and earlier used a short board and the '64up used the longer one. In fact, there are at least 5 different running boards that I have seen that were used on the various fj40s. The 64-78 long boards should interchange, but the '79up will have the cutout for the body seam. The 72ish with the factory diamond plate are by far the best made (and the simplest.)
