factory roof removal a real pain II
Discussion in '80-Series Tech' started by 97cruiser, Sep 15, 2003.
  1. 97cruiser
    97cruiser
    317
    Aug 7, 2003
    Lewiton, Idaho
    I need to know exactly how the rack is connected,I have the 2 front screws removed on both the front and rear mounts but the 2 longer ones on both the front and rear mounts wont come out.Stripped maybe?I pull up on the rack while unscrewing but cant get them to catch and come out.Is the rack "plugged" into the roof with rubber grommets maybe? pleas don't tell me I have to remove the headliner to acces a couple nuts under the roof. Thnx,Vince
  2. anderaa13
    anderaa13
    254
    1
    Aug 22, 2003
    Fort Collins, CO
    It sounds like the threaded inserts in the roof may be spinning. when i took my rack off there was rust around these and one of them was actually loose.
    aaron
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,978
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Agreed.
    Most likely the nutserts are spinning in the roof skin (they are steel and are likely rusted). You may need to drop the headliner and get hold of them from the underside. I'm sure you didn't want to hear that but that may be your best bet.
  4. 97cruiser
    97cruiser
    317
    Aug 7, 2003
    Lewiton, Idaho
    Ya I'm sure they are spinning.Any ideas on how to get them to catch?
