Facing Safety Pad removal?
Discussion in '40- & 55-Series Tech' started by Perfect_Obsession, May 28, 2003.
  1. Perfect_Obsession
    Perfect_Obsession
    15
    May 28, 2003
    Bonjour,
    I have to remove wiper mechanism. I removed 5 retaining screws and 2 bolts but the safety pad still resist.
    Do you have some tricks?
    P.O.
    P.S.: I have a 1978 Canadian FJ-40
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    There's a set of clips across the back. You have to push it in, I believe to get them to release.
  3. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Bon jour, PO.
    If it is like my 71, and I believe they are the same, the clips are part of a strip of metal welded onto the firewall, and the whole process inserts into a slot along the back of the pad. The clips just clamp onto a metal strip screwed into the Dashpad/safety pad. My clips were rusted quite solidly to the dashpad metal strip, which is inaccessable when clipped, and removal therefore required GREAT FORCE, if I recall correctly, in the form of a pry bar. The clips are at an angle to the firewall, facing upward and to the rear, about 60 degrees off vertical, so pry up and back.
    IDave
  4. Perfect_Obsession
    Perfect_Obsession
    15
    May 28, 2003
    Thanks everyone.
    I got it. I pushed clips with screw driver and pulled up & back at the same time. Nothing rusted.
    Therefore I was able to reposition wiper blades. They were pointing the sky when stopped. Now they rest at the bottom of the windshield.
    Thanks again. :bow:
    P.O.
