Exhaust system for v8 fj40
Discussion in '40- & 55-Series Tech' started by lostnate, May 3, 2003.
  1. lostnate
    lostnate
    4
    May 3, 2003
    Does anyone know if there are prebent exhaust kits available for chevy v8 converted fj40's? Also, has anyone tried using blockhugger headers with v8 conversions that also have a saginaw power steering conversion? Will there be enough room between the steering shaft and the engine block?
    Anyhelp is appreciated.
  2. beanz2
    beanz2 Moderator
    2,124
    6
    Nov 16, 2002
    I used to run blockhuggers with a Saginaw. There was enough room, but your conversion may be different. My whole exhaust system was made at the muffler shop with aluminized tubing. It cost me $150 w/o muffler, with an exit behind the rear pasenger tire.
    Dave
  3. woody
    woody Internet Fireman Staff Member
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    blockhuggers are great....summit for $80 I think....and no, there isn't a prebent-option for exhaust, I had a custom crossover made with a single exhaust out the back, ran about $200 IIRC. Any decent small exhaust shop can bend custom stuff easily. Avoid the big places, make sure you fine a shop that understands exactly what you want.
  4. theo
    theo
    1,432
    Feb 19, 2002
    Another thought:
    I wanted dual exhaust for the notes but I let the shop talk me into running the tubes under the frame and mounting the mufflers under the rocker panels, with the exits in front of the rear tires. Big mistake since the tubes and mufflers are all susceptible to crushing even from minor wheeling situations. You should try and keep the entire exhaust system above the level of the frame.
  5. woody
    10,329
    Media:
    303
    1,084
    Jan 15, 2002
    Toquerville UT
    [​IMG]
    Unfortunately, a great shot of my exhaust system...all above the frame, has never been crushed....and yes, there have been many many many opportunites to crush it!  lol
    Only change I would make now is a center in-offset out muffler rather than offset/offset.
  6. theo
    theo
    1,432
    Feb 19, 2002
    A selfless act of kindness tipping your cruiser over just to answer a question on the forum. That's dedication!
  7. burrows
    burrows
    10
    Mar 31, 2003
    I would go with the block huggers, they just are more out of the way. I am running the outside framerail style and they work fine but i have hit my mufflers multiple times.
    burrows
  8. Rice
    Rice SILVER Star
    3,262
    Media:
    10
    2,557
    May 2, 2003
    GSO NC
    When going to the muffler shop (I'm using block huggers) I insisted on 2 things ... Dual 2 1/2" lines all the way back and I wanted the pipes turned down behind the rear wheels (like on old Nova's and Chevelle's). Happy with the results and it all fit.
    Sorry, I haven't flipped it over for a picture yet.
    Good Luck,
    R
  9. cmilliron
    cmilliron
    39
    Nov 3, 2002
    It's all relative to how much time and $$$$ you are willing to spend... I love to fabricate in steel... so the only choice for me was a hand made set of tuned headers that fit, are turned, and put the muffs between the frame rails...
    Lots of folks sell header kits on line...
  10. Slowerthanu
    Slowerthanu SILVER Star
    1,326
    8
    Apr 23, 2002
    Bountiful, Utah
    Woody, have I mentioned how much I love that pic :D
    Gettin' it!!!!!!!
    If you run dual exhaust inside the frame try to fit an H pipe in the equation, it will help with low end torque delivery and it will sound much better.
