excessive heat around the transmission cover
Discussion in '40- & 55-Series Tech' started by sambudo, Jun 28, 2003.
  1. sambudo
    sambudo
    120
    Jun 24, 2003
    Wheaton, IL
    Is their anything that can be done to get rid of all that heat? What have you done to prevent that. Winter time it is ok, but in the summer at 90+ degree F. It tends to get really hot! Suggestions or comments.
  2. 1973Guppie
    1973Guppie
    8,742
    Media:
    31
    625
    Jan 31, 2003
    "the whale's vagina", CA
    Is it exhaust heat or dtrain heat? I would guess exhaust. I am having the same problem on my vortec as my cats are running right underneath the dside next to the dtrain. I could cook breakfast before on my tranny hump. hopefully a heat shield will work to deflect most of the heat. I plan to take it to a muffler shop that can set it up with some type of shield, I also plan to use dynamat extreme on the tranny cover and floorboards, this is supposed to help deflect heat some as well. Then some matting on top of that.
    hth,
    Noah
  3. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    The tranny hump on my 74 gets hot on the highway as well. Since my temp guage never reads above the low line of the "normal" area on the highway I don't worry about it. I figure its lots of hot air from the engine being forced through there by the curvature of the firewall.
