Engine Removal (fj40)
Discussion in '40- & 55-Series Tech' started by KNUCKLEDRAGGER, Sep 19, 2003.
  1. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    I am swapping my F motor out for a SBC350 and will be pulling the F motor out this weekend.
    Should I try and pull the engine/trans/t-case all together (seems like to much) or just the engine/trans and remove the t-case 1st by itself ? (up through the floor ?)
    I have the hood/grill/driver fender off already to help with acess, Is there anything else to do or watch for to make this easier/safer ?
    Thanks
  2. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Re:Engine Removal Q (fj40)
    If you're going SBC pull the whole thing. It all needs to come out any way.
  3. Bobsbash
    Bobsbash
    43
    Aug 29, 2003
    I agree. Pull it all out at once. I find it easier this way too.
  4. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    Thats really going to be a job...those casters on the the hoist SUCK !
  5. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Lube the wheels and sweep the floor.
  6. woody
    woody Internet Fireman Staff Member
    10,331
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    One big long package....and install the SBC the same way. Piece of cake, my record for pulling a I-6 and dropping in a V8 AND getting it running is 4-1/2 hours
    :D
  7. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    That's Pretty good. 78 One owner and I swapped a V8 in a couple hours though.
  8. Pete_S
    Pete_S
    74
    Feb 3, 2003
    A small floor jack with casters is good under the transfer/tranny area, for the in as well the out.
  9. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    Getting ready, after a can of penetrating oil and a days work.
    Can anyone tell me about removing the shifter ? I read that you push down and twist...is that all there is to it ? Before refering to the mesage board I used a punch and pushed in the pin on the drivers side of the shifter housing....did I screw up ?
  10. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    Ok...I unbolted the top of the trans and removed the whole assembly...but still couldn't get the shifter out. :mad:
  11. woody
    10,331
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    I use a slip-jaw wrench and simply push and rotate the retaining collar for the shifter. Pops out every time. The metal collar needs to go down ~1/4" then get rotated.
  12. residualboulders
    residualboulders
    274
    Media:
    1
    20
    Apr 2, 2003
    its not as steady, but my brothers and I have installed a couple of engines - and took the old ones out with the old John Deere front loader. Lifts the engine real easy, and you don't have to worry about little casters on the hoist. Kinda hard to align things though ;)
  13. KNUCKLEDRAGGER
    KNUCKLEDRAGGER
    124
    Jun 23, 2002
    Thanks Woody, I was pushing that collar down and trying to rotate the stick part of the shifter. It will probably work alot better your way !
    and Jake wouldnt you know it I sent my front loader to the cleaners....never fails. :whoops:
  14. Iron_Pig
    Iron_Pig
    116
    Dec 4, 2002
    Knucledragger,the main frustration I had with getting the shifter out is the Haynes manual told me to turn it the WRONG direction :doh:. When you press it down, Turn it counter-clockwise,not clock-wise.
  15. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    If the casters on the engine hoist are a concern, position the cruiser so you can roll it out from under the engine/trans/t-case combo.
  16. GBLUM
    GBLUM
    1
    Mar 12, 2010
    South Florida
    Thanks guys,, i am pulling my f2 in the morning,, have everything removed and un bolted with the front of the cruiser removed.. I stopped this evening because i was wondering whether i should remove all at once or not.. You answered my question. Will remove the shifters in the morning and pull all together . Thanks again
  17. fjjonnie
    fjjonnie
    183
    Apr 7, 2009
    low desert of So Cal
    so, with a handle like "Knuckledragger" I've got to ask, what other rides do you own?
  18. bikersmurf
    bikersmurf
    6,758
    Media:
    59
    427
    Apr 2, 2008
    Victoria, BC
    When putting it back in the 350 is lighter. I pulled the front fenders, grill, and hood off when I did mine. I also have used the roll the truck trick when swapping frames (when lifting the tub and also the transfer/tranny/engine combo) solo. 31" tires roll much better than 3" castors.
