engine rebuild - parts recommendation
Discussion in '40- & 55-Series Tech' started by pvaman, Jul 15, 2003.
  1. pvaman
    pvaman
    129
    Apr 11, 2003
    85 FJ 60 - 200K miles - blowing smoke badly and despite my wife's urging i don't want to part with my cruiser.
    I'm going to need to have the bottom end of the engine rebuilt and would like recommendations on supplier/parts for this. I may need oversized pistons if the cylinder walls are in poor shape but it there anything else that i should consider doing given that i'm going to this trouble? I've got the stock carb (and i think i'd like to keep it) and the heads recently been rebuilt.
    What's your favorite supplier for this stuff? SOR, Manafre, ???
    Thanks in advance.
  2. bsilva132
    bsilva132
    1,008
    Media:
    5
    5
    Jan 14, 2003
    Elk Grove, Ca
    try pac-lift in san diego. I don't have a #, but try a search on this board for "pac-lift" as the # has been posted before.
  3. pvaman
    pvaman
    129
    Apr 11, 2003
    Thanks...i saw one reference to this in an earlier post. It was a little unclear what exactly they provided.
  4. MD11Fr8Dog
    MD11Fr8Dog CM09 Eight Ball winner
    539
    4
    Apr 6, 2002
    Southern Pines, NC
    [quote author=pvaman link=board=1;threadid=3678;start=0#msg27163 date=1058374123]
    [/quote]
    Whatever you want!! Call PacLift, talk to Al. He'll ask what you need, and you tell him!! Al will hook you up!!
  5. pvaman
    pvaman
    129
    Apr 11, 2003
    I talked to Al -- really nice guy -- and the prices seem pretty good.
    What's the quality of these parts - compared to other aftermarket parts and toyota parts. Anyone had any problems with 'em. Seems like the warrenty was really short ... i want to say 30 days.
    CCOT has a pretty complete kit w/some of the parts being toyota parts but the price is over 2X :(.
    Still undecided as to whether to rebuild or buy a used/remanufactured long block.
  6. petescoffee
    petescoffee
    1,824
    19
    Dec 29, 2002
    Walnut Creek, CA
    On the TLCA mailing list last week a emailer indicated the the parts were Toyota. Ask him who manufacturers the parts. I used a local Landcruiser shop to get the parts for my 75 2F. During my research Pac lift came up numerous times as the place to get your parts. The basic parts- Pistons, rings, bearings, toyota gasket set etc. will run you around $1000. Everything else you need.. Machine shop work (deck the block and cylinder bore, crank turning, New water pump, carb rebuild, Plastigage, Header? will run you another $1000.
    Also, plan on boring the cylinders. You have the motor a part you might as well bore it out for the extra compression.
    Good Luck
  7. MD11Fr8Dog
    539
    4
    Apr 6, 2002
    Southern Pines, NC
    [quote author=petescoffee link=board=1;threadid=3678;start=0#msg28336 date=1058884947]
    Good Luck
    [/quote]
    I paid between $500 and 600 for my parts from PacLift, about $350 for machine work - hot tank, painting of block, honed cylinders, valve grind/job and head mill. Another $130 for a cam shaft! All told, about $1100 plus my labor and few odds and ends.
  8. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    That's more than I spent putting in a 350!
    Go Chev.
  9. pvaman
    pvaman
    129
    Apr 11, 2003
    I talked to Al again and it sounds like Pac-Lift's parts are in fact Genuine Toyota parts -- i.e. they buy them directly from the same distributor/manufacturer as Toyota.
