I have a 93 that suddenly started missing hard yesterday morning. Ran fine Sunday evening, ran rough Monday morning. It has always had a bit of a miss until warm since I've had it. Warms up and runs fine. A while back it started missing hard like this and I found a vacuum line unhooked. Fixed that and it went away.
This time it feels the same, but I can't see a line unhooked or broken. Haven't had a chance to check with propane or spray yet. The CEL has been on with an O2 sensor code. Checked again today and no new codes. Pulled fuse to reset codes and it hasn't came back on.
Seems to be most pronounced at around 1500 rpm. Say 1200-1800, but it's there at all rpm. Truck has always idles a little high to me. 800 idle in drive, 1100 or so with AC on. This with the miss would make me think vacuum leak, but I figured that would throw a code.
Could use all the tuneup parts, but I just really don't need to spend the money right now. I'm afraid that's the problem, but I want to check anything else I can first. And seems odd that plugs, wires, etc would get that bad overnight.
So my question is what will cause engine to run rough, but not throw any codes? What are the simple things to check first.
