Electronic ignition in FJ55
Discussion in '40- & 55-Series Tech' started by cruiser_guy, Sep 3, 2003.
  1. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    Wherever the truck stops!!
    Anyone know when the FJ55 got electronic ignition? I've got a '76 FJ55 (Feb. '76) which has electronic ignition but needs a wiring harness and I have a wiring harness from a Nov '74 FJ55 are they compatible? ???
  2. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    Someone out there has this info or knows where to get it.
  3. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    FJ55 has the same engines same year as FJ40's. Whenever 40's were switched, 55's were switched.
  4. Landpimp
    Landpimp GOLD Star
    14,679
    869
    Mar 14, 2003
    PNW
    pretty sure 74(and 75 I think) won't work. 78 or 79 was the 1st year with full electonic ignition, 76-78 is semi electonic.
    try looking up the ignition parts on SOR, that should tell you more.
  5. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,978
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    75-77 had points and an Igniter. 78+ were full electronic. The Ca. spec vehicles may have been earlier, I don't recall at the moment.
    D-
  6. Pin_Head
    Pin_Head
    13,731
    1,297
    Feb 6, 2002
    OC, CA
    If it is just an ignition wiring harness issue, the harness should be the same up to the ignitor. The major wiring changes in later years have to do with smog control parts.
  7. cruiser_guy
    cruiser_guy
    11,209
    22
    Jan 20, 2003
    Yes it is just a wiring harness issue. The PO hacked up the harness so all bets are off if it's all there or going to the right places. This is all stock. The ignitor made me think electronic ignition but it may well have points, I have not yet looked. We're in the middle of restoring it.
