- Joined
- Sep 25, 2011
- Threads
- 84
- Messages
- 3,631
- Location
- Harbour City, the New Southern Wales
- Website
- www.freewayoneentertainment.com
Halogen lamps draw way more than stock ones. I'd say that's your issue.
I'd say you're overthinking all of this . Check the battery voltage at idle . Compare voltage drops around the system - at the fuse box , alternator main battery post and headlight voltage at idle . It can be the way the alternator is tied into the system - without a centralized point for the alternator to read amperage loads the main system voltage can drop too far and give the coil pack system a negative effect on Chevy engines - see this all the time . I just re-wired half the engine bay of a '62 Belair Wagon and gave it a central connection point for the alternator , battery and fuse box system . It never deviates from 14.5v , idle or otherwise . It's basically the same system setup that is outlined on Mad's tutorial pages - just with my input to tie it into an old Chevy system that originally used the horn relay as the central point of detection .
Sarge
FYI: The voltage regulator regulates the voltage output of the alternator and thus regulates the (available) Amps.
More rpm = more Volts = more Amps. When the voltage goes up, the VR controls the voltage output to max set point.
Should be between 14 and 14.8V
If the rpm is too low and the demand too high, the voltage will drop. The alternator can not do its job at low (idle) rpm.
It's just enough to keep the ignition going.
As said before; it's pretty normal behavior. Add another set of fog lights and the engine will die at idle.
There is simply not enough energy available at idle.
If you want the bright light at idle..... pull the throttle a bit.
Rudi
It is normal behavior and it is unlikely it has anything to do with the ignition. You are looking at the increased HP that it takes to turn the alternator. Remove the alternator belt to confirm or rule this out.
