Ok, so I'm finishing up my switch panel and electrical "to-do's".
Currently, I have my electric fan (high setting) on a rocker switch, and would like to add a temperature controlled switch.
If I purchase just a sending unit, that kicks on the high speed fan around 205*, how do I wire it into the existing setup?
Current high speed setting wiring;
IGN HOT > Rocker Switch > Relay > High Speed on the fan.
Basically the high speed will only active while the ignition is on, and the rocker switch is turned on.
I "think" the correct setup for this would be something like this.
IGN HOT > Rocker Switch (override) > Relay > Sending Unit > High Speed. I'm thinking the sending unit splices into the IGN HOT (86) on the relay, so when the SU gets to 205* it will trigger the relay to kick on.
