Wondering if someone could suggest an electric fan for my pig? I have a TBI 350 and want to make sure the cooling is efficient. Radiator suggestions would also be great....
Doug
Doug
Hi Aaron,This is what I came up with after seeing what Profitts set up looked like. The fan used to be attached straight to the radiator 350 mild build was running 210-20 on a hot day. Now won't go over 205. Radiotor is from champion.
Thanks for your reply. I had a challenge since I'm very limited on depth of fan (installed VintageAir a/c with condenser and double pulleys). Anyway, I had a breakthrough today - I found that the Fiat Abarth 595 fan with some cutting of "ears" fits very well and cool the engine with A/C on perfectly. I suffered long time from overheating when in traffic on a hot day with a/c on....I use the two speed Taurus fan bolts up to the radiator mount perfectly. Cools great too.
Thanks. You said you are using the taurus 2 speed fan - do you know which model it is (which taurus years) and what its thickness is?Nice. Looks like a good fit
Do you have air condition installed?Champion 4 Core radiator MC180 22"x22.13" x 2.75"
I have a Derale 2 stage fan 16822 in a shroud that does a good job keeping temps down. Especially now that I have the timing not advanced too much.
Thanks. The reason I asked is because there are 2 issues when ac installed:No AC installed. Although I do have an AC compressor that came with the vehicle that had previously been used for on board air.
Hey buddy, incase it helps. I've run two junkyard pulled, Taurus fans, over the years. They each went bad after a couple years. Last time I decided to try a new aftermarket Taurus fan and had good luck. I found this one on Rockauto. It's VDO, 80 bucks, appears to be well made, and has been working great for the last couple years. IMHO this is a better route to go instead of using a junkyard pulloff fan.Thanks. You said you are using the taurus 2 speed fan - do you know which model it is (which taurus years) and what its thickness is?
Thanks for the info Brian. If this is a 1995 Taurus assembly, I saw it at the importer warehouse and it's very deep....won't fit my space between the radiator and water pump pulley....please correct me if I'm wrong. Thanks.Hey buddy, incase it helps. I've run two junkyard pulled, Taurus fans, over the years. They each went bad after a couple years. Last time I decided to try a new aftermarket Taurus fan and had good luck. I found this one on Rockauto. It's VDO, 80 bucks, appears to be well made, and has been working great for the last couple years. IMHO this is a better route to go instead of using a junkyard pulloff fan.
VDO FA70113
edit, ..this fan comes with the female side of the electrical connector but not the male. So you'd need to either splice the wires or find a Ford male fan connector.
