EGT Temp Guide (1 Viewer)
Hello again.
The idea of this post is to hace in a single place different EGT temp records and experience.
Before i went Turbo I spended several hours reading the forum.
And after i turbo´ed, i spend even more hours.
So, for thoes super freaks, for people who are considering to put a turbo... of just for anyone to consult, I think that this list it could be very usefull
The idea is not to discuss if the EGT you are getting are too high or too low, just to have many data son then each of us can compare, get an idea of what are le lowest values, the higest values and see if they fall more or less in the middle (if we can collect enough data, I might then make some nice graph!).
I recommend to copy & paste the following list of values so everyone has the same data recorded.
If anyone thinks I might be missin something, pls add it
Thanks and regards.
Pablo
Rig data:
Model: BJ70
Motor: 3b
Turbo: Yes
Intercooler: No
Tyres: 255/85/16 (like 33x10.5)
Exaust: 2.5"
Egt probe location: Pre turbo
Trans: 5 spee
Diff: 4.11 (std)
Curising Data:
Speed: 60 mph (97 kph)
RPM: ???
GPS or Speedo: GPS
Av. Temp: 80 F (27C)
Altitude : 0
Boost: 10.5 psi
EGT Temp: 860 to 950 F (470 to 510 C)
Rig data:
Model: BJ74
Motor: 13bt
Turbo: Yes
Intercooler: Yes
Tyres: 315/75R16 (35''x12.5'')
Exaust: 3'' Including dump pipe
Trans: 5 speed manual
Diff: 4.11 (std)
Curising Data:
Speed: 100km/hr
RPM: 2200
GPS or Speedo: GPS
Altitude : 400m
Boost: 10 psi
Max Boost setting: 22psi
EGT Temp: 450
Rig data:
Model: FJ62
Motor: 2H
Turbo: No
Intercooler: No
Tyres: 33x10.5x15
Exaust: 2.25 into 2.5 muffler
Egt probe location: Manifold
Trans: H55
Diff: 4.11
T-case: 2.88/0.92
Curising Data:
Speed: 100kph
RPM: 2100
GPS or Speedo: GPS
Av. Temp: 75F
Altitude : Florida
Boost: n/a
Max Boost setting: n/a
EGT Temp: 900
Rig data:
Model: HJ60
Motor: 12HT
Turbo: Yes (high flowed ct26 with billet wheel)
Intercooler: No
Tyres: 33X12.5X15
Exhaust: 3" Straight Through
Egt probe location: Post turbo
Trans: 5 speed
Diff: Cable Locker...dont know gear ratio
Curising Data:
Speed: 100km/h
RPM: 2250rpm
GPS or Speedo: GPS
Av. Temp: 20c
Altitude : ??
Boost: 8psi
EGT Temp: 290C
Tencha: HJ60
Engine: 2H
Turbo: KKK 26.8
Intercooler: Top Mounted aprox 12" X 12" core area with Mishimoto Fan on top / Alcohol Injection
Tires: MTR 40" X 13.5 R17
Exhaust: 2.5 Straight pipe
EGT probe: exhaust manifold
Trans: H55F
Axles: 4.56
Cruising Data:
Speed 100km/h
RPM: 2100
Speedo / GPS
Av. Temp: 30C / 90% Humidity
Atitude: mostly sea level
Boost: 4PSI ( 14 PSI max wastegate regulated )
EGT Temp: 800F
1987 HJ60
Engine: 2H
Turbo: "Nissan 16V" from RB20det Skyline (gt25 size approx)
Intercooler: Audi 12x12"/24v electric fan
Tires: 35x12.5x15 Bfg KM2
Exhaust: 2.5" straight Dump pipe 3 feet long
EGT probe: adaptor flange pre-turbo
Trans: H55F
Axles: 3:70
Cruising Data:
Speed 100km/h + -
RPM: 2000rpm
Boost: 4psi@2000rpm 5th gear
Max boost 10psi
EGT Temp: depending on wind 700-950@2000rpm 5gear
Max hillclimb EGT: 1300
Rig data:
Model: BJ42
Motor: 3B
Turbo: Yes
Intercooler: No
Tyres: 36" x 12.5 x 15"
Exaust: 3" turbo back
Trans: 5 speed
Diff: 4.11
Curising Data:
Speed: 100km/h
RPM: ???
GPS or Speedo: GPS
Av. Temp: 70 F (22C)
Altitude : 0
Boost: 10 psi
EGT Temp: 750 to 800 F (400 to 430 C)
Rig data:
Model: LJ78 (1990 Toyota land cruiser Prado)
Motor: 2/lte
Turbo: Yes
Intercooler: No
Exaust: 2.5" (side dump)
Trans: 4 speed auto
Diff:
Cruising Data:
Speed: 50 KPH
RPM: ???
GPS or Speedo: Speedo
Av. Temp: 18C
Altitude : ??
Boost: 5-9 psi
EGT Temp: 600 to 800 F
Max hillclimb EGT: 1000-1100 F
Model: HZJ77
Motor: 1HZ
Turbo: Yes (Old Gturbo running CT20 Turbine - Supra Comp Wheel)
Intercooler: HPD Top Mount with no fan as of yet, big ugly STI scoop
Tyres: 255/85/16 Toyo MT
Exaust: 3'
Trans: 5 speed
Diff: 4.11 (std)
Cruising Data:
Speed: 100km/h
RPM: 2250
GPS or Speedo: GPS
Av. Temp: 18 deg C
Altitude : Sea Level or just above it
Boost: 12lbs flat highway, bucking headwind 15lbs. Max 20lbs under full load
EGT Temp: 650-750 depending on the load.
Max Hill Climb: 1000f-1100f
Rig data:
Model: FJ60 - 1985
Motor: Isuzu 4BD2tc
Turbo: Yes - Stock NPR with waste gate
Intercooler: Yes - stock Isuzu NPR
Tyres: 33x10.5X15 BFG KM2
Exaust: 2.5"
Trans: 5 speed
Diff: 3.70 (std)
CruisingData:
Speed: 65 mph
RPM: 2200
GPS or Speedo: Both
Altitude : 100
Boost: Cruise 7 psi on flat - 17.5 psi max
EGT Temp: 700 cruise up to 1150F under full load
Model: HDJ81
Motor: 1HD-T
Turbo: Yes (FACTORY)
Intercooler: NONE
Tyres: 315/75/16 BFG MK2
Exaust: 3'
Trans: AUTO A442f hydraulic
Diff: 5.29
Cruising Data:
Speed: 110km/h
RPM: 2400
Av. Temp: 18 deg C
Altitude : 1,045 m (3,428 ft) above sea level
Boost: 13.5 - 14 psi flat highway, Max 16 psi under full load
EGT Temp: 750-800 depending on the load.
Max Hill Climb: 1000f-1150f Fully floored can go as high as 1600f really fast on a hot day.
Model: LJ78
Motor: 2LTE
Turbo: CT20A (OEM)
Intercooler: Water to Air Intercooler (27"x7"x2" front mount radiator)
Tires: 235/85/16 Good Year Wrangler Territory
Exhaust: 2.5" Mandrel with Aeroturbine 2525xl
Egt probe location: Post turbo about 1.5" from turbine center
Trans: A343F Auto
Diff: 4.88
Cruising Data:
Speed: 100km/h
RPM: 2450
GPS or Speedo: GPS
Av. Temp: 20C
Altitude : 0-500m
Boost: 5-7psi flat highway. Max 16-18psi (depends on meth injection on/off)
EGT Temp: 400-600F
Max Hill Climb: 900F (worst case scenario towing up big hills in 30C+ temps)
Model: HDJ80
Motor: 1HD-T
Turbo: GTurbo
Intercooler: Air to Air Top Mounted with electric Fan on top ( IIRC was about 14" X 14" or so )
Tires: 315/75 R16 Toyo Open Country MT ( heavy as hell )
Exhaust: 3" straight short pipe ( ends front of rear tire )
EGT Probe Location: Exhaust Manifold
Tranny: H150
Axles Ratio: 4.10
Cruising Data:
Speed: 100km/h
RPM: about 2200 - 2300
GPS / Speedo: Speedo ( apply tire correction )
Ave Ambien Temp: 30°C / 84°F
Altitude: Sea Level
Boost: 10PSI average, max 24 - 26 PSI ( depends on alcohol injection or not )
EGT Temp: Cruising 700°F ( 100km/h )
Max Hill Climb: 1400°F and climbing if nailed
From this weekend
Rig data:
Model: BJ74
Motor: 13 B-T
Turbo: Yes (factory CT26)
Intercooler: No
Tyres: 33x10.5R15 BFG KM/2
Exaust: 2.5"
Trans: Auto (A440f)
Diff: 4.11
Cruising Data:
Speed: 70 MPH
RPM: close to 2200
GPS or Speedo: GPS (speedo is way off ... 70MPH is ~97kph on speedo)
Av. Temp: 75F
Altitude : 750 ft.
Boost: 6-7 psi
EGT Temp: 750 - 800F
Max boost is a hair over 9 PSI.
Coming home from Logan's Run last night on a few hills at lower speeds and driving like an idiot (lower RPMs, climbing a hill and loosing speed with pedal almost matted) saw a spike to 1150F. Generally is driving sanely, I don't see much over 1050F.
Rig data:
Model: HDJ80 - 1991
Motor: 1HDT
Turbo: GTurbo FTE BBX S3
Intercooler: XXi water to air
Tyres: 35x12.5x16 Maxxis Trepador
Exhaust: 3"
Egt probe location: Pre turbo, in manifold collector
Trans: 5 speed
Diff: 4.56 (regeared for 35's)
Cruising Data:
Speed: 100 km/h
RPM: 2600
GPS or Speedo: Both
Av. Temp: 40+C
Altitude : 356m ASL
Boost: Cruise 10-15 psi on flat - 38 psi max
EGT Temp: 300-350C cruise up to 600C under full load (uphill, towing 2+tonne)
AFR: 16:1 prespool, 18:1 WOT
Rig data:
Model: - 1981 BJ60
Motor: 3B
Turbo: cxracing TRB-GT2052V
Intercooler: none
Tyres: 33 x 12.5 x 15
Exhaust: 2.5" straight piped
Egt probe location: pre turbo
Trans: 4 speed
Diff: Stock?
Cruising Data:
Speed: 100 km/h
RPM: 2200
GPS or Speedo: GPS
Av. Temp: 30+C
Altitude : 350m ASL
Boost: 13psi max by 1800RPM
EGT Temp: 250-400F idle, 600-800F on flats, up to 1000F hoggin up hills but let off the gas at this point
Model: HDJ81 1993 JDM Toyota land cruiser 80 series
Motor: 1HD-T
Turbo: Yes, stock
Intercooler: No
Tyres: 315/75/16 (heavy mt)
Exaust: 3" with muffler
Egt probe location: pre-turbo manifold
Trans: A442F
Diff: stock 4.11
Cruising Data:
Speed: 100 km/h
RPM: 2,300
Av. Temp: 24C
Altitude : 700 metres
Boost: 13.5 psi
EGT Temp: 600 to 850 F
Max hillclimb EGT: 1100-1300 F
