EGR Cooler - needed on TBI 2F?
Discussion in '40- & 55-Series Tech' started by OlympiaFJ60, Apr 30, 2003.
  1. OlympiaFJ60
    OlympiaFJ60
    1,032
    2
    Apr 9, 2002
    Olympia, WA
    I have the manifolds off fixing a crack in the intake manifold floor and was wondering (since the pipes are loose already), should the EGR cooler be retained in the EGR system? I am running a GM TBI setup. The exhaust-cooler pipe needs to be repaired/replaced and I was wondering if I could just go strait to the EGR valve.
    Brandon
    Olympia, WA
  2. Erics75
    Erics75
    81
    Jun 14, 2002
    I'm not sure exactly what you mean, removing the egr vavle will give you problems at smog time because it reduces your combustion chamber temps thereby reducing the hydrocarbons if I remember correctly, so removing it will increase the levels of HC's.
  3. OlympiaFJ60
    OlympiaFJ60
    1,032
    2
    Apr 9, 2002
    Olympia, WA
    I want to retain the EGR valve, just want to know of any ill affects of removing just the cooler.
    Thanks
    Brandon
