EASIER OIL CHANGE
Discussion in '80-Series Tech' started by cruiserdan, Apr 18, 2003.
  1. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    If anyone tells you it's easier to get to the filter from below.......DO NOT BELIEVE THEM.....
  2. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Hey Dan, you lost something, and it wasn't the oil filter.
    -B-
  3. firetruck41
    firetruck41
    5,732
    10
    Mar 27, 2003
    Camas, WA USA
    :eek:WOW! :eek:
    Well now that you got it apart that far, you might as well check your brake pads. That way you can be more efficient, you know, two birds with one stone! ;)
  4. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    -B- Did not, it's right here........... 8)
  5. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Turn off the compressor and step away from the truck. All that work and you still don't have the oil out of it!
    After seeing that picture I think I understand why it cost so much to have the oil changed at the local lube shop. I had no idea I had been doing it wrong all these years! :G
  6. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Better get a skid plate for that thing.
    Bill
  7. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Well, Bill has let the cat out of the bag. I have been working for some time on an extra capacity oil filter. I have however, been faced with some "fitment" issues.................Every time you spin it on, the front axle clearance cut ends up in a different place :dunno:
  8. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    that must be the large filter we keep hearing about :eek:
  9. Photoman
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Sorry Dan. :tear: Here is the wrench as requested.
  10. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Much better, Thanks. I had a helluva time bear-hugging the durn thing :G.
  11. Wrench
    Wrench One Bashed Up 80
    4,492
    178
    Mar 27, 2003
    Ok enough joking around. What the heck are you doing Dan? Was all that necessary? ???
  12. theferg
    theferg
    2,251
    Media:
    2
    84
    Dec 22, 2002
    wandering the wild wild west
    [​IMG]
    Ya, what are you really doing?
  13. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Before Bill got a hold of it I was installing a front axle housing with electric diff lock........ :beer:
  14. Wrench
    4,492
    178
    Mar 27, 2003
    Cool! Keep us posted. :D
  15. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Wrench,
    Nothing to keep you posted about. It was an old pic I found and decided to have a bit of fun with it. The job was one I completed some time back and it functions as OEM original.
  16. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I see you went to KMart to get your impact wrench, I have the same one.
    The neighbor gave me the same square metal tall box in the second pic. What are they from?
    kurtl
  17. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Kurt, The impact wrench did not come from Kmart. It is a cheapy one though. The square metal "can" is a wheat storage tin. They hold about 35 lbs of wheat. They are also used for rice and other grains. They are used for long term storage. We have some full ones packed in the 70's, and yes the wheat is still good, we use it all the time.
    The wife grinds it and makes yummy bread with it. :beer:
    I get the old cans to play with, oil drains, parts cleaners, etc..... 8)
  18. Wrench
    4,492
    178
    Mar 27, 2003
  19. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I saw the black plastic band around the rear of the tool. Mine say Air Power with a T over U. I see it with several doifferent stickers on it at store. When I tried to remove the drive shaft flange bolts it did nothing. I went to Sears and got a bolt snaper impact wrench. 450 forword, 600 reverse at 90 lbs. Crank it up to 150 lbs and stand back. ' Don't do this at home, you might get hurt'.THe metal from the bolts and nuts were flying all over till they broke loose.
    kurt
