Early model brakes
Discussion in '40- & 55-Series Tech' started by landcruiser, Jan 26, 2003.
  1. landcruiser
    landcruiser
    27
    Jan 24, 2003
    Has anyone here converted the ealry model single circuit brake master cylinder to a later model dual master cylinder? Is this a bolt on proposition with the exception of line re-routing and which master cylinder would you recommend?
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    Unless you are updating to disc brakes at the same time, you'll need a drum master to keep the residual valve. 74-75 Cruisers were the last two years for drums and I would think that would be your best choice for doners.
    I don't forsee any connectin problems.....I have heard that running a booster/master may interfere with your carb/air cleaner assembly on some earlier setups tho, so make sure you have room.
  3. plan66
    plan66
    31
    Jan 28, 2003
    When I did the brakes on my '66, I used a 70's Ford drum brake master cylinder. I still have the drum brakes, but it should be possible to remove the residual pressure valve if/when I go to disks. Biggest problem; the cylinders one inch bore makes for VERY heavy pedal effort. No booster, but it'll still lock em up :D. I just didn't want to mess up my firewall, but if you can use one of those spacers to get the booster to clear the rib, might be the way to go.
    Cheers
    Martin
