Now the dimensions.
Height from the top of bow to the top of the tailgate: 32-1/2"
my measurements will be in RED
32 3/4"
Now the dimensions.
Height from the top of the windshield frame to the top of the bows. Board was resting on the top of all three bows: 3-11/16"
(My wood wasn't straight so I actually measured 3 1/2" from one side and and 3 7/8" from the other.)
Door height from the top of the door opening to the opening in the horizontal door surround: 40-15/16"
Door opening from the windshield frame to the opening in the veritical door surround. 27-1/2"
(try to ignore the 1/2" stock "light tabs" installed by PO..........)
The tabs for the horizontal bar between the center and rear bows are slotted. I had mine set exactly in the center of each of these slots. (first pic)
Now the distance from the vertical door surround all the way to rear bow: 49-9/16"
Center bow width at the bottom (from the outside of each vertical door surround: 63-1/2"
Center bow width at the top (from each vertical door surround): 62"
Rear bow width at bottom : 61-3/4"
[/QUOTE]QUOTE=Cruiser_Nerd;4995739]Rear bow width at horizontal bar: 60-1/2"
(Try to ignore those holes, another PO mod....)
From the channel on the windshield frame, all the way along the top of the bows to the rear bow: 78-1/2"
Again, this is with the horizontal bow in the center of the slotted tabs.
32 3/4"
I actually measured side to side per Jim's and also flipped the board for two more measurements and still came up with 3 11/16
78 1/2" also
