Dyno results : 2F-E vs 2F carbed
Discussion in '60-Series Wagons' started by Yspen, Oct 7, 2012.
  1. Yspen
    Yspen
    455
    Media:
    14
    23
    Jul 7, 2007
    Cape Town , SA
    EDIT : the tuning was incorrectly done . Information in the first few posts is misleading .
    The dyno tuning was redone and gave much better results than indicated in first post
    Rather skip to Post 14 in the thread
    For academical purpose here follows my experience :
    2F Block overbore 0.060" ( Toyota pistons and rings )
    ARP conrod bolts
    Delta 250S cam
    SBC valve springs
    Dyno graph - Efi engine with stock compression ratio ( aftermarket ecu )
    As you can see the engine power was still climbing when the tuner stopped the run .
    [​IMG]
    In comparison : The carbed engine with higher compression ratio ( 3F carb head with kidney shape chambers and 9,5:1 CR )
    [​IMG]
    I find it strange that the Torque of the carbed engine shows it to be higher at 2000 rpm than with the Fuel injection - when I drive it , it "feels" like there power at lower revs with the new Fi . Strictly speaking the graph of the carbed engine looks like it performs better than the Fi-engine . It was done on two different dyno machines , two years apart .
    If fuel consumption is lower with Fi then I regard the process as a success - if not ... well I enjoyed the research and development .
  2. Cruzerman
    Cruzerman
    1,643
    137
    Apr 23, 2005
    Oregon
    I was expecting more from the EFI motor. I've been eyeing the 2F-E conversion but was expecting more. Perhaps I was just being unreasonable. I'm going to have to give that more thought.
  3. Yspen
    Yspen
    455
    Media:
    14
    23
    Jul 7, 2007
    Cape Town , SA
    I would love to see what the graph would be like below 2000rpm as I spend most of my time there in Daily Driving . With the efi it "feels" like there is more power at idle to 1500rpm . Throttle response is quicker without a doubt .
    The tuner said the 3F-E injectors have a limited pulsewidth ( 255 ) and he could get more out of the car at higher rpms if the injectors were bigger . He was suggesting upping the rail pressure with adjustable fuel pressure regulator and seeing what happens .
  4. Mace
    Mace rock scientist.. Staff Member s-Moderator
    20,164
    793
    Feb 17, 2002
    Las Vegas
    Using different machines that is pretty much an apples to oranges comparison unfortunately.
    GLTHFJ60 likes this.
  5. toyofj60
    toyofj60
    390
    Media:
    70
    13
    Apr 4, 2011
    nc
    What does that convert to in horsepower and lbs/ft tourqe??
  6. coolotisdog
    coolotisdog
    463
    Sep 4, 2008
    Arizona
    It's about 135 hp at the rpms they have for the 2fe
  7. RockDoc
    RockDoc my bad habit SILVER Star
    6,653
    Media:
    3
    302
    Jun 3, 2007
    SW MB, Ca
    A couple of quick questions/points:
    Your carbed 2F had a compression of 9.5:1, from numbers I wrote down when I was doing my 2FE a "stock" compression would be 8.6:1 for 3FE head on a 2F. Does this jive with what you figure?
    Everything under the head was the same for both setups, correct? Same cam, no work on the bottom end before either that would need break-in?
    I recall you did some port work on the carbed head, did you do any with the EFI head?
    Do you notice any difference in smoothness at high rpm between the two setups? My 2FE gets "vibey" above 3500 rpm, but I have attributed that to the crank not being balanced (I think the shop screwed me on that job), but maybe I'm wrong and the fuel flow is an issue at high engine speed.....
  8. Yspen
    Yspen
    455
    Media:
    14
    23
    Jul 7, 2007
    Cape Town , SA
    The 3f-e head was placed as I received it from the US. My thumbsuck was 8,6-8,7 CR.
    One reason for not skimming the head is that you do not find them in africa and it needs to last. Less stress on the head and some meat for future skimming. It cost me $1000 just in shipping charges to get it here.
    The rest of the bottom end was left unchanged. Only placed new valvesprings and used stock valve clearances .
    Above 3500 rpm the valvetrain is noisy as it was after the rebuild 2 years ago.
    At the time we readjusted the valve clearance to oe spec and then fitted the SBC valvesprings. All that took the tappet noise down . After a few 1000miles the tappet noise settled completely and I hope the same will happen now.
    The carbed head was a aweful cast and needed some porting . The 3fe head was actually quite smooth and did not show the ugly ridges and grooves of the carbed head - so it was left and not ported.
    Engine truns smooth though above 3500 rpm and it is above 4200 rpm where the injectors start showing its limit - that is according to the tuner as I have not had the opportunity to take it there.
    In daily driving the revs go to 1800-1900 rpm and the I change gear. So the part where the engine spends most of its time does not show in the graph.
    In that range the car feels stronger and quicker response on throttle.
    When I get time I will take the car to the dyno where the carbed run was done for a more fair comparison
  9. Yspen
    Yspen
    455
    Media:
    14
    23
    Jul 7, 2007
    Cape Town , SA
    I had my regular mechanic check the setup and he thinks the ecu mapping is incorrect.
    The car does not run as she should. The is overfueling and at idling this morning we had to leave the workshop due to the emissions .
    We checked the timing and it was set after TDC and not before TDC.
    Think I need to find a new dyno- tuner
  10. red803f
    red803f
    31
    Aug 26, 2012
    Geraldton, Western Australia
    Wow!! That would make a big change in power being retarded like that, was your dizzy left loose maybe?
  11. RockDoc
    6,653
    Media:
    3
    302
    Jun 3, 2007
    SW MB, Ca
  12. Yspen
    Yspen
    455
    Media:
    14
    23
    Jul 7, 2007
    Cape Town , SA
    We should delete this thread and start over as there is too much misleading info .
    Car was re-tuned today on dyno.
    Tuner still not happy and will continue tomorrow. He says there is an hesitation when he did a road test between 1500 and 2000 rpm
    So far today the final dyno run:
    115kW
    310nm
    Will post the printout when I get it
  13. FJ40Jim
    FJ40Jim The Cruiser Whisperer
    8,950
    675
    Sep 26, 2003
    Lancaster, Ohio, USA
    They should graph out the AFR as well as power.
  14. Yspen
    Yspen
    455
    Media:
    14
    23
    Jul 7, 2007
    Cape Town , SA
    OK , here is the printout of the final dyno today .
    You can see where the before graph ( how the first tuner set it ) lower line and after the second tuner set it . ( higher line )
    [​IMG]
    Compare that to carb again ( the efi is higher in torque and Hp during the whole rev range )
    [​IMG]
  15. gregnash
    gregnash GuiltyByAssociation SILVER Star
    6,073
    603
    Nov 4, 2011
    Carson City, NV
    So top sheet is the 2F and the bottom sheet is the 2FE?!
  16. Yspen
    Yspen
    455
    Media:
    14
    23
    Jul 7, 2007
    Cape Town , SA
    No , top sheet is 2Fe with aftermarket ecu and bottom sheet is 2F
    ( lower graph only goes to 4400 rpm and top one to 5000rpm )
    @ 2000 rpm :
    2F = 240Nm , 2Fe = 260 Nm ( roughly the same HP )
    @ 3000rpm
    2F = 275 Nm / 90 kW , 2Fe = 305 Nm / over 100kW
    2Fe max values :
    115.7 kW @ 3970 rpm ( that is 155hp at the wheels )
    308Nm @ 3009 rpm
    2F max values :
    109.3 kW @ 4400 rpm
    274 Nm @ 3445 rpm
  17. GeologistFelix
    GeologistFelix
    647
    6
    Dec 28, 2010
    Bellingham, WA
    For my those who prefer horsepower/foot-pounds, that's, very conservatively, assuming only a 20% loss for the drivetrain, about 190 hp/255 ft-lbs at the crank.
    That's like 40% more horsepower through most of the power band, and 20% more torque than the factory values for the 2F.
    Cool.
  18. gregnash
    6,073
    603
    Nov 4, 2011
    Carson City, NV
    Thanks for the translation Felix. That is a pretty impressive gain from the conversion.
  19. FJsnoozer
    FJsnoozer
    1,977
    40
    Apr 13, 2011
    Austin, Texas
    What type of aftermarket ECU did you use?
    I am sorry, it was a little difficult to follow the progress of your ECU. are these stock internals, or was there some type of zerobalance done to the shortblock?
    Thanks again for the response.
