Drywall behind Sterling tub/shower enclosure?
Discussion in 'Workshop and Home Improvement' started by haystax, Apr 1, 2010.
  1. haystax
    haystax
    1,261
    Mar 9, 2004
    Diamond Valley, Nevada
    Finally getting back to work on the basement, hung the bathroom ceiling last night and now I can't find directions for the Sterling tub/shower we installed last year. I have never installed these units, only a tile-in type tub.
    I guess I don't need any drywall behind the enclosure panels?? Straight to the studs?
    Can't get the installation instructions for this particular unit online, but I looked at some others and there is no drywall mentioned.
    Here is the unit:Sterling Plumbing: Ensembleā„¢, Tile Bath/Shower: Bathtub Showers: Baths & Showers
    Thanks for your help!
  2. jjbodean1970
    jjbodean1970
    1,218
    12
    May 10, 2004
    Morgantown, WV
  3. Joe_E
    Joe_E
    3,550
    Media:
    39
    126
    May 31, 2008
    the NJ word..
    Yep, tubs and shower enclosures are installed during the plumbing stage in new construction which is before the rock. Overlap your rock over the lips of the tubs or enclosure.
  4. Michael Hanson
    Michael Hanson
    7,666
    Media:
    3
    25
    Oct 30, 2007
    Plano texas
    No rock,but we insulate behind and under to cut down on noise transfer. MIke
  5. haystax
    haystax
    1,261
    Mar 9, 2004
    Hey guys thanks for the help, had a little brain lapse since the plumber set the tub but left the enclosure to me.
    Tub is an inch away from the back wall but the sides are just right to be flush. I dunno...it will cover;)
    Bodean - thanks for the link!
  6. jjbodean1970
    jjbodean1970
    1,218
    12
    May 10, 2004
    Morgantown, WV
    no problem, be sure to post pics when youre done :beer:
  7. 79fj40moneypit
    79fj40moneypit
    1,237
    Media:
    13
    1
    Oct 6, 2006
    Poorhouse, CT.
    I found that before you install sheetrock you should rip strips of wood and nail them on the studs around the shower enclosure to keep the sheetrock nice and flat, the strips should be a tad thicker than the flange. it also helps when you put the baseboard around the wall the baseboard stays straight instead of being cocked over 5 or 10 degrees. Also when you put the sheetrock on apply waterproof caulk to the bottom of the rock it really helps in the long run.
  8. haystax
    haystax
    1,261
    Mar 9, 2004
    I stood up the shower walls last night to get an idea of how it fit and marked where I need some blocking and studied my 1" gap against the ICF wall.
    Forgot to mark the valve and spout cutout - :doh:
    I'll work on it again tonight and it should be good to go, I will probably go overboard on the use of silicone as well.
    What about trim where the sheetrock meets the tub enclosure? Thinking about just using the plastic door trim I plan to use on the rest of the bathroom.
  9. hydro joe
    hydro joe
    36
    Media:
    3
    Nov 12, 2009
    When installing shower or tub surrounds fire blocking is needed at the edge around the top 3/4" down.
  10. haystax
    haystax
    1,261
    Mar 9, 2004
    Good to know - I blocked the heck out of everything and drywalled for fire barrier against the ICF
    Need to cut the shower valve in and it will be good to go
    Thanks!
