Driveline options
Discussion in '40- & 55-Series Tech' started by fr8train, Jun 27, 2003.
  1. fr8train
    fr8train
    100
    Jun 27, 2003
    Maryland
    First off, great site guys. I am the proud owner of a '65 FJ 40!!!!! Unfortunately its got a rod thru the block. Now since I have a 383TBI just gathering dust would it be a good idea to mount it up? Making an adaptor to the three speed is not an issue. Or would it be a better idea to get the drive train from a 76-up FJ40 or FJ60 and mount it behind the 383?
  2. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,099
    Jan 15, 2002
    Toquerville UT
    383TBI to a stock 3-speed boat anchor is a waste of $$ IMO
    BUT...use the 383 to a SM465 or SM420 granny tranny with a plate adapter to your stock t-case and you not only have a stronger tranny, you gain a granny gear.
    my concern then would be the t-case....run a http://www.tcase.homestead.com on there and it will help a ton for strength.
  3. fr8train
    fr8train
    100
    Jun 27, 2003
    Maryland
    Thanks for the info. I just read the manufac. forum and found that adaptor option. I have both the 465 and 420 trannys. Does anyone on here have a NV4500 running with their stock case or have they switched to a GM or atlas case?
  4. woody
    10,336
    Media:
    303
    1,099
    Jan 15, 2002
    Toquerville UT
    NV4500 is nice with the OD but it's a long option and lots more $$ than the non-OD SM465.
    GM/Atlas are center outputs and require a rear axle change too.
    Check the tech links for tranny swaps and there are a few writeups there to give you more ideas...lol
