Drain Plug Seal T-case
Discussion in '80-Series Tech' started by landtoy80, May 21, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I pulled the leaking drain plug seal out of the less than 1yr old new t-case. I have several of the drain plug seals for the diffs. The t-case is a solid seal, the diff seal is a crush type seal. Will the diff seal work on the t-case?
    kurt
  2. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    In using the crush type diff drain plug seal, which way does the seal go? There is a smooth side and a side that crushes?
    kurt
  3. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Kurt,
    The xfer case is aluminum and your diffs are steel. Use the proper gasket. I know your dealer is a long way but having the right parts on hand is something you'll have to plan for before draining the xfer.
    -B-
  4. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    I replaced all my drain plugs with these low profile magnetic ones (tcase, tranny and diffs).
    [​IMG]
  5. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I used the old seal from the old t-case. If it leaks I am only out the price of the oil.
    kurt
  6. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Chris,
    Where did you buy your plugs at?
    Bill
  7. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Bill,
    Factory plugs of that design are available. They are used most often in Trans oil pans.
  8. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    Yep the plugs and gaskets are a dealer item. All Pro Off Road sells them mail order for $4 each.
  9. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    Chris
    I can't believe how clean the underneath of your truck is. You must either have very clean roads or else you've got a pressure washer...
    Jim :eek:
  10. Chris_Geiger
    Chris_Geiger
    305
    Mar 28, 2003
    I think I am the first person to ever put this one in low range. The under side looked like new when I got it.
  11. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    What is the torque spec. for the drain/fill plug?
    kurt
  12. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    The leak was not the drain plug seal. It is leaking next to the drain plug. The seal for the front extensiln housing assembly is leaking. As the t-case less than a year old, I will get to find out how Toyota deals with their parts warranty. I installed the t-case my self. I never had a new Toyota part fail.
    kurt
