drain location for standard 5' shower/tub?
Discussion in 'Workshop and Home Improvement' started by MoJ, May 28, 2008.
  1. MoJ
    MoJ Moderator
    3,310
    76
    Oct 24, 2003
    Basement is pre-plumbed for a bathroom. I'm framing the walls that will form the bathroom. I plan on installing a standard 5' shower/tub combo. How far should the center of the tub drain be from the wall at the head of the shower? Distance from the side wall?
    Thanks.
  2. Pin_Head
    Pin_Head
    13,750
    1,318
    Feb 6, 2002
    OC, CA
    The distance varies depending on the width of the tub and it can be left, right or center. Pick your tub first and then frame it.
  3. Toyo FJ40
    Toyo FJ40
    1,021
    Media:
    8
    Dec 7, 2004
    Eastern PA.
    On a standard tub the drain will be about an 1 1/2 inches off the frameing behind the drain. Like Pinhead said the center will depend on the tub. Tub traps connect below the overflow not the drain. You can get rough in specs for most tubs online. Kohler Roughin Specs
    Kevin
  4. RHINO
    RHINO
    3,765
    2
    Dec 23, 2003
    valley of the sunstroke, AZ
    yeah its tough, you usually get a choice of width. as said above either buy the one you want or decide on it and get the dimensions.
  5. MoJ
    MoJ Moderator
    3,310
    76
    Oct 24, 2003
    Kevin -
    Thanks! On another site I had read 1.5" from the wall at the head of the tub but kept thinking that couldn't be right. I hadn't been considering that the trap was below the back of the overflow rather than the drain. What's even better is that the center of the pre-plumbed drain sticking out of my basement floor is exactly 1.5" from where my wall needs to go to accomodate a 5' tub. Geez it's so much more fun when you don't have to bust up concrete.
    :beer:
    Jason
  6. GAS-A-LOT!
    GAS-A-LOT!
    1,202
    Media:
    1
    Oct 18, 2006
    LOS ANGELES
    Sounds like your good to go....:clap:
  7. -Spike-
    -Spike-
    6,238
    47
    May 26, 2005
    Phoenix
    Is there a trap already installed?
    -Spike
