downey front cradle motor mount
Discussion in '40- & 55-Series Tech' started by FJ40Dude75, Dec 29, 2002.
  1. FJ40Dude75
    FJ40Dude75
    248
    Nov 12, 2002
    has anyone used this with a 350 sm465 swap with mini truck ps and if so how did it work?? thanks for any input
  2. Plowboy
    Plowboy
    798
    Apr 21, 2002
    On a hill overlooking a lake in Idaho
    I used the downey motor mount with a 327. There was a problem with trying to mount a powersteering pump. The 327's use the same bolt holes for the powersteering as the downey does to mount the channel to the block. With a 350 this should not be a problem since the pump mounts to the head. The downey mount does not center your engine. It is slightly offset to the left (driver side), just like the toyota 6. You need to use a rear dump manifold because of clearances with the steering box. Over the frame headers will not work, #5 exhaust passes directly over the return outlet. only 1/2 inch clearance. Cannot get the fitting and tube in. Any other questions about the motor mount system, let me know.
  3. FJ40Dude75
    FJ40Dude75
    248
    Nov 12, 2002
    is it worth it to use it or should i go with weld ins The motor has rams horns on now but i was looking into block huggers but will they work ? and also what did the cradle mount cost?
  4. Plowboy
    Plowboy
    798
    Apr 21, 2002
    I can't give you a good idea on a price for the cradle, I installed mine over 20 yrs ago. I now have weldin's to accomadate the powersteering pump. If I were to do it again, I would use the over the frame mounts that use the stock chevrolet motor mounts. I don't remember exactly where to locate these, but you might try Bob Firestone on the LCML list, or see if Woody has a listing on the tech section. As far as the rams horn on the driver side, the adjusting nut on the box hit the collector, just above the bolt flange. This was with the engine slide over toward the passanger side as far as it would go. I have been considering block huggers myself, but I would like to see a pair on a block and take some measurements
  5. rick_d
    rick_d
    1,298
    97
    Apr 20, 2002
    the cradle mounts are ok, but weld ins are the way to go. A victim of a front end accident (cruiser was ok) had the engine break free and go through the radiator about 4 years ago in Tucson. The plate failed so I hear. Needless, he switched to weld in mounts after this when repairing the truck.
