Does the shifter have light?
Discussion in '80-Series Tech' started by lovetoski, Sep 7, 2003.
  1. lovetoski
    lovetoski SILVER Star
    4,421
    119
    Jul 13, 2003
    Just figuring stuff out in our new (to us) fzj80...after the sun set tonight I noticed that the notations PNRD21 next to the shifer are not lit up. (They are lit fine on the dash.) Is this correct, or does a light bulb need replacing?
    Thanks,
    Doug Graham
  2. AZcruiser
    AZcruiser
    332
    Jun 24, 2003
    phoenix
    they dont light up.
    CHris
  3. ParadiseCruiser
    ParadiseCruiser
    620
    Mar 27, 2003
    Doug -
    Chris answered your question correctly, but a clarification...
    On the 95-97 models, there is a backlight under the shifter gear letters "PNRD21" that is on when the headlights are on, but it is a difuse light intended to help the driver see the shifter - it does not indicate what gear you are in. Those, like yours are on the dash.
    Don't know if this is also the case with 94 and earlier models.
    Cheers, R -
  4. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    The indicator at the shift lever is also "back-lit" on the 91-94 80 series. For that matter, all Toyota automatic transmission indicators mounted at the shift lever are "back-lit" regardless of year or model.
  5. lovetoski
    4,421
    119
    Jul 13, 2003
    Cuiserdan,
    Since I appear to have no backlight at the shifter, can I assume that there is a bulb that I can replace? My FSM has not arrived yet, and the owners manual doesn't say anything about replacing a bulb in this area?
    Thanks!
  6. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Yes, there is a bulb that you can replace. You will need to remove the console to access it. I don't remember off-hand the number. I can look it up for you tomorrow and post back.
  7. lovetoski
    4,421
    119
    Jul 13, 2003
    Thanks Cruiserdan - the part number would be great - I really appreciate your help!
    Best Regards,
  8. - S.A. -
    - S.A. -
    350
    1
    Mar 27, 2003
    JERSEY
    The center shifter lightbulb is a standard automotive bulb..You can get the light bulb at autozone or any other car place. If i remember correctly..think it is the same lightbulb as the glovebox bulb. It is about $1 at autozone.
    later..
    -Joe-
  9. lovetoski
    4,421
    119
    Jul 13, 2003
    SA and Cruiserdan - found a replacement bulb at a local auto parts store. Feeling kinda dumb for asking the question in the first place, since it turned out to be such an easy fix. But thanks to your kindness, one little thing is fixed.
  10. DanKunz
    DanKunz
    8,855
    Media:
    2
    523
    Feb 7, 2002
    Woodstock, GA
    1 thing down, 16 to go!
  11. - S.A. -
    - S.A. -
    350
    1
    Mar 27, 2003
    JERSEY
    Hey LOVETOSKI..
    You fix list will prob look like this..after a few weeks on this board! :D
    1. Replace shifter light bulb.
    2. Buy OME J Springs
    3. Buy BFG MT 315's
    4. Buy ARB Bullbar
    5. Buy Warn M12000 Winch
    6. Buy OME Steering Stablizers
    7. Buy OME Shocks
    8. Buy TRD Super Charger
    9. Buy Slee Rear Bumper
    10. Buy Slee Skid Plate
    11. Replace "antenna up/down" button lights!
    -joe-
  12. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Um, Joe....
    I believe you meant to say #1 Buy TRD Super Charger.... ::)
  13. lovetoski
    4,421
    119
    Jul 13, 2003
    No question, the list of stuff to do is growing. Fortunatly the truck runs really well, so I have time to be methodical. In which case I got some good advice from Kurt...
    What I did was:
    Replace;
    all wheel baarings
    steering bearings
    diff bearings ( the front didn't need it and the rear I havent done yet)
    plugs,wires cap rotor
    pcv
    spark plug seals, valve cover gasket
    all fluids; brake,power steering,tranny,diff, t-case, coolant etc
    tie rod ends
    Inspect;
    birfields, mine were worn so I got Newfieds (cheaper than OEM)
    u-joints, I replaced them, they didn't need it
    check valves
    clean intake chamber ( to fix egr problem)
    this should keep you busy for a couple of weeks
    kurt
    Once I get most of that stuff taken care of, and some stereo upgrades, I can get to work on all the fun stuff you guys are talking about. No question, this is an addiction. It's good, but hard to "let go of."
    See ya,
