Doable? Toyta 4.5 Litre V8 Turbo Diesel Engine Swap
Discussion in '80-Series Tech' started by RichElliott, Jun 10, 2008.
  1. RichElliott
    RichElliott
    186
    Media:
    41
    2
    Mar 24, 2008
    Portland, Oregon
    Hi all!
    I was checking out the latest FJ70 on Toyota's Australia page and was impressed with what I learned about their new 4.5 Liter V8 Turbo Diesel Engine. 20% more power. 30% less weight. 20 to 25 mpg.
    So it got me thinking... how cool would it be to get my hands on one of these engines w/ the manual 5 speed transmission and swap them into my 97 fj80? Since diesel's are much more efficient than gasoline engines at low RPMs, this would make an awesome trail rig.
    Thoughts?
    Has anyone else already tried this?
    Links:
    Toyota's Page
    Interesting Article
  2. Brian894X4
    Brian894X4
    1,257
    5
    Feb 26, 2004
    Oregon
    They had to redesign the front end of the 70 to make it fit. The 70 was designed around the 2F and later 3F and the 1FZ itself was designed around the dimensions of the 3F to back fit all the previous models and the 80 series was designed around the 3F/1FZ, so I have to wonder if there would be fitment issues. There's probably more room in an 80 than a old 70, but who knows.
    Beyond that, the cost of obtaining one of those engines is probably beyond astranomical, but if I ever won the lottery, I'd sure look into it.
  3. F0RSAKEN
    F0RSAKEN
    236
    Jun 4, 2006
    You would be better off in every aspect by just putting a Cummins into your FZJ. It's cheaper, simpler, easier to fix (assumption), and would probably, if you went with the 4BT, get better efficiency.
  4. WarDamnEagle
    WarDamnEagle
    2,365
    3
    May 20, 2007
    Tampa and Gulf Shores
    I think you will have trouble legally importing this into the US. I've looked into importing diesel vehicles and engines into the US and it isn't easy (unless the vehicle is over 25 years old). The fines listed are also pretty stiff. Just FYI.
    But it would be cool!
  5. ThePookieBear
    ThePookieBear
    868
    Nov 9, 2006
    Wichita, KS.
    I seriously doubt the 4BT is more efficient than the new V8. Its an old design. The 1HZ or 1HDT would be a better bet. They would be close to bolt up, and probably still more efficient than the 4BT.
  6. NoMoreFires!
    NoMoreFires!
    141
    May 2, 2008
    Columbia, MO
    Just swap in a cummins, do a turbo/intercooler and convert it to WVO. Then make real good friends with the owner of a local fast food joint---free gas forever!
  7. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    21,840
    574
    Apr 4, 2003
    Panamá
    Interesting .. you must need to buy the hole drivetrain, V8 and ECU .. keep in mind that the single turbo from a 70 series are less powerfull than the other twin turbo that come in the 200 series and both run a variable vane turbo with D4D tech inside .. ( common rail )
  8. Hilux
    Hilux
    2,158
    3
    Apr 2, 2008
    Nashville Tn.
    I just love posting this....gotta love...the Gov!
  9. TX80Fan
    TX80Fan
    342
    2
    Feb 27, 2007
    State of Flux...
    ...anything is possible with the right wallet
  10. Jason Andrews
    Jason Andrews
    472
    1
    Dec 15, 2005
    Aloha Beach, CO
    There, fixed it for ya:D
  11. roscoFJ73
    roscoFJ73
    13,076
    Media:
    3
    222
    Jul 22, 2003
    Perth Western Australia
    They are actually VDJ78/79 series;)
    4WD Action magazine say the 105 series looks as if it would have enough room to do the V8 diesel swap.
    As the 105 and 80 share a similar chassis,you could assume it doable.
    The hard part is finding the engine:D
  12. hj60
    hj60
    1,511
    3
    Apr 9, 2003
    Ahwatukee, Phoenix, AZ, USA
    Just remember to cut the economy numbers by about 1/3 when you bring a foreign diesel here.
    And if it's not common rail, you'll need to figger in the cost of lubricity additives, or a pump rebuild every few 10k miles.
    Thank you to the E(verybody's) P(ain in the) A(ss).
  13. RichElliott
    RichElliott
    186
    Media:
    41
    2
    Mar 24, 2008
    Portland, Oregon
    Thanks!
    Thanks for all the awesome input! This is really more of a pipe dream for me, but I still think it would be really cool. I did some more research and found some good information that might address a couple of the questions here regarding common-rail and emissions:
    From Jarvis Toyota in Australia, I found the following:
    [​IMG]
    Engine:
    The 1VD-FTV engine which powers the LandCruiser 70 Series vehicles has been developed as Toyota’s first V8 diesel engine. This engine with its advanced technical development provides improved fuel efficiency. Lower emissions which comply with Euro IV regulations and reduction of noise has also been achieved.
    Engine Intercooler and Piping:
    The 1VD-FTV engine has a single turbocharger with an air to air intercooler located above the engine to enhance output and exhaust performance. The intercooler is fed air via the bonnet scoop sculptured into the bonnet.
    Engine Specifications for the Toyota Landcruiser 70 Series:
    Engine Model: 1VD-FTV
    Number of cylinders and arrangement: 8 cylinders, V-type
    Bore x stroke: 86.0 x 96.0mm
    Displacement: 4.461cm3
    Compression ratio: 16.8 : 1
    Valve mechanism: 32 valve, DOHC
    Intake system: Turbocharger with intercooler
    Fuel system: Common-rail type
    Emission regulation: Euro IV
    Maximum output: >150kW
    Maximum torque: > 400Nm
    Transmission:
    The H150F 5-speed manual transmission has been retained for the facelift LandCruiser 70 series. This transmission has been modified for use with the new 1VD-FTV engine.
  14. ncrockinfj
    ncrockinfj
    350
    1
    Mar 29, 2007
    Chicago, IL
    so does that mean that the 1fz would be an easy fit into a 3fe cruiser?
  15. 1shot1kill
    1shot1kill
    886
    188
    Sep 30, 2005
    NW
    ya think!
    A guy in my neck of the woods went this route and after nearly 30k and counting the rig still does not run!:rolleyes:
  16. Tapage
    21,840
    574
    Apr 4, 2003
    Panamá
    The interesting part .. which mods . ? :D
