Dissolving rubber?
Discussion in '60-Series Wagons' started by Landcruisin'60, Jul 10, 2007.
  1. Landcruisin'60
    Landcruisin'60
    1,216
    1
    Nov 14, 2006
    VT
    Is there a quick way to dissolve rubber? It doesnt have to be minutes but something I could put on and in the morning be able to remove my shackle bolts more easily? I have tried a puller, torch and banging the bolts with a rather large sledge hammer. But nothing is working. The front came out quickly but on the rear there seem to be sleeves that have rusted to the bolt and somehow stuck to the rubber and they wont come out. I need to get this done soon because I am behind schedule.
  2. GulfShoresFJ60
    GulfShoresFJ60
    888
    Feb 12, 2005
    MS
    You can cut the shackle bolts with a sawzall. Put the blade between the shackle and the shackle hanger and just cut the shackle bolt. The bolt should be easier to remove - now you can pop the bushing out with the bolt.
  3. tclndcrz
    tclndcrz
    989
    Mar 30, 2003
    Charleston SC
    you could torch it out
  4. 60wag
    60wag SILVER Star
    1,909
    24
    Jun 25, 2003
    Boulder, CO
    There isn't a practical solvent for the bushings. Lighting them on fire with a torch is the easiest way to go. Pressing them out with a hydraulic jack is an option that doesn't make quite as much smoke.
  5. Landcruisin'60
    Landcruisin'60
    1,216
    1
    Nov 14, 2006
    VT
    Yeah I have been torching them but it take a long time and smells horrible.
  6. VTCruiser
    VTCruiser
    3,440
    6
    Sep 12, 2003
    Tacoma, WA
    agreed, burn 'em out. :cool:
  7. cabron
    cabron
    1,730
    Media:
    2
    1
    Jan 18, 2005
    Louisville, Kentucky
    would brake cleaner work? it eats my gloves:)
  8. crawlin60
    crawlin60
    135
    Feb 27, 2002
    dude, just torch the crap out. Rubber gets gooey when hot enough and then you just crank the come-along attached to the shackle and wham-o, problem solved.
  9. Gappy
    Gappy
    2,898
    20
    May 24, 2005
    NE Indiana
    Here is what I have done, remove the nut and shackle. Set up a fan to blow the smoke away and torch the rubber and the threads right at the rubber. Do that until the at least a portion of the bolt is red hot, then beat the hell out of the bolt to push it out. If it doesn't work, more heat for a longer time, gotta break down that rubber. Watch out for hot flying rubber shrapnal when you start swinging the hammer. If you didn't get hot flying rubber, you didn't heat long enough. Once the bolt is flush and the hammer is no good, get some steel bar stock to beat on and push it through. If you do need to cut, I recommend a medium sized hand grinder instead of a saw, cuts quicker.
    Good luck!!
  10. agent orange
    agent orange
    2,230
    4
    Jul 8, 2005
    Richmond, VA
    I drilled some holes in the really stubborn bushings because i didnt have a torch, that made a big difference.
  11. lowtideride
    lowtideride
    7,596
    Media:
    12
    69
    Sep 29, 2003
    The Sunshine State
    Ive used plenty of methods. BFH normally works. But, I have used a high lift jack from one bolt to another and highlifted them out at the same time ;)
  12. brett76
    brett76
    1,264
    1
    Aug 17, 2005
    t town, wa
    i just sawzalled a section of the bushings
  13. Landcruisin'60
    Landcruisin'60
    1,216
    1
    Nov 14, 2006
    VT
    Ok I am going to try to drill them out and then torch them. I am low on oxygen so I dont really want to use the torch a whole lot on burning bushings.
  14. AfricanToy
    AfricanToy
    527
    Mar 5, 2006
    USA
    take a quick pic...for us onlookers. We all want to partisapate
  15. Landcruisin'60
    Landcruisin'60
    1,216
    1
    Nov 14, 2006
    VT
    I can, in the last 1-2 hours of beating torching and spraying PBblaster I got one shackle bolt out. This could take a while.
  16. phishincruisin
    phishincruisin
    566
    Feb 8, 2007
    VT, MT
    you just aren't hitting them hard enough :cool: when we took blaines out of his leafs on his toy, tom and i just used propane torches to slowly melt them out, there wasn't any need for the heat of the oxy-mapp torch. it worked really well. just get g'pas mapp torch and go after it.
  17. Landcruisin'60
    Landcruisin'60
    1,216
    1
    Nov 14, 2006
    VT
    Yeah, yeah, yeah of course im not hitting it hard enough. :whoops: I'll get the mapp torch tomorrow and see what I can do. I am so sick of taking stuff apart I want to put stuff back together:mad:
  18. lowtideride
    lowtideride
    7,596
    Media:
    12
    69
    Sep 29, 2003
    The Sunshine State
    Are you torching the rubber or the bolt?
    If you have a hot enough torch I would torch the bolt til it turns red hot then pound it out.
  19. Landcruisin'60
    Landcruisin'60
    1,216
    1
    Nov 14, 2006
    VT
  20. lowtideride
    lowtideride
    7,596
    Media:
    12
    69
    Sep 29, 2003
    The Sunshine State
    If you tryed heating up just the bolt and it dint work you dint get it hot enough.
