Disc. brake problem
Discussion in '40- & 55-Series Tech' started by ryeguy, Mar 26, 2003.
  1. ryeguy
    ryeguy
    18
    Feb 17, 2003
    Hi there,
    I got a hold of an '85 4runner front differential and started pulling it apart to clean it up and do the disc conv. with my '74 FJ40 . My problem is ... I can't seem to separate the hub of the 4runner from the spindle(bearing housing) Iwas just wondering if there is a trick to doing this or what :-/
    thank you
    Ryan
  2. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
  3. ryeguy
    ryeguy
    18
    Feb 17, 2003
    Thanx for the links. It looks like it's a straight forward process like any other hub. Mine must just be frozen on or put on with a generous helping of some kind of liquid gasket material.
    thank you again
  4. ryeguy
    ryeguy
    18
    Feb 17, 2003
    :-[OOOOppsss.I read it too fast the first time. Looks like the "cone washers" that are giving me the hard time. I'm glad I double checked before "beating the hell" out of the hub :-/.
    rye
  5. Design311
    Design311
    203
    Apr 25, 2002
    Bella Vista, AR
    Yeah, you need to beat on the cone washers with a brass drift. Back the nut off flush with head of the stud and wack the brass drift hard a couple of times. They should pop out. If not you might try spraying them with some penetrant like PB Blaster or Liquid Wrench. Good luck!
