Differential gasket - needs sealant?
Discussion in '60-Series Wagons' started by Spanky Pete, Aug 26, 2009.
  1. Spanky Pete
    Spanky Pete
    311
    Dec 21, 2008
    Oregon
    I am about to put the third member back together and I am not sure about the gasket. I have read the diff cover gasket, which is cork, doesn't need any sealant, just set it up dry.
    The 3rd member to axle gasket from toyota is a different thinner paper material. Should I lay a bead of permatex on there?
  2. GLTHFJ60
    GLTHFJ60 Rum Runnin' SILVER Star
    18,940
    2,519
    Apr 18, 2005
    Durham, NC
    Don't need to, but it can't hurt. I've done both with the dry toy gasket and with just RTV. Neither leaked.
  3. BGarcia88FJ62
    BGarcia88FJ62 SILVER Star
    985
    55
    Dec 1, 2004
    Calhoun, Ga.
    I've never used anything more than the gaskets. Unless you mauled it getting it off and bent or put a groove in it or something gaskets are all you need IMO.
    :beer:
  4. KLF
    KLF Frame waxer SILVER Star
    6,283
    489
    Apr 5, 2003
    Southern NH
    I always use a gasket, with a thin bead of RTV on both faces. Reason is for removal: when you need to take it back out, the gasket will split. But the layer of RTV will make peeling it off with a razor scraper much easier.
  5. cruiser88
    cruiser88
    11,876
    Media:
    3
    28
    Feb 21, 2006
    Medford Oregon
    I never have used a gasket.......just permatex:beer:
  6. specialk396
    specialk396
    469
    Aug 4, 2009
    Waynesboro, Va
    RTV
    I use either RTV and gasket or RTV only, depending on if I have the paper/cork gasket. On a thick mounting flange like is on these diffs, RTV should be fine.
  7. nuclearlemon
    nuclearlemon not an addict Moderator
    15,557
    Media:
    87
    389
    Jan 30, 2003
    meh-ico, colorado
    i've never used any sealants outside of hightack to keep the gasket in place when i stabbed the diff.
  8. wengejor
    wengejor
    1,235
    1
    Oct 14, 2007
    MidWest
    I just swapped 4.11's into my truck last week...I didn't use sealant on both and the rear didn't leak, but the front did. I used a razor blade to remove the old gasket material, but the front didn't seal up. I had to drain it, loosen it up and put some goop on it. I didn't fill it back up yet...giving it a few days to cure before refilling it w/ 90w.
  9. lehiguy
    lehiguy
    3,792
    16
    Mar 18, 2008
    Lehi, Porter Rockwell's home town
    I hate to admit how many Toyota center sections I've pulled, I always removed the gasket and used RTV only, never had a leak. RTV is used by many axle manufactures these days, and no gasket.
  10. zebrabeefj40
    zebrabeefj40
    3,180
    22
    Feb 19, 2004
    Pepperell MA
    I've had better luck with RTV only than with any combination of gaskets and goop on diffs... YRMV!
    :cheers:
    Nick
  11. cruiser guy
    cruiser guy
    1,545
    Media:
    1
    31
    Mar 22, 2009
    Sandy, UT
    I have always used rtb, its pretty forgiving if you get a skinny bead in an area, and removing it isn't all that bad either
  12. rusty_tlc
    rusty_tlc Dain Bramaged Member
    12,946
    Media:
    3
    561
    Jun 23, 2005
    Reno, NV
    What are these "gaskets" of which you speak?:confused:
    [​IMG]
  13. lehiguy
    lehiguy
    3,792
    16
    Mar 18, 2008
    That's the one! That is an actual Dodge part, they don't use gaskets on their diffs, just the Ultra Grey specificly.
  14. ntsqd
    ntsqd technerd
    5,046
    80
    Apr 26, 2007
    Upper So. CA
    I used the "Right Stuff" when I put the FF in. I've used it on an NP241's cases as well. No leaks. Not looking forward to taking either apart, but I didn't put it together intending to take it apart anytime soon.
