Did I burn out my starter?
Discussion in '40- & 55-Series Tech' started by Larr75fj40, Mar 26, 2008.
  1. Larr75fj40
    Larr75fj40
    365
    1
    Jan 12, 2007
    Garden Grove, OC- CA
    I had my Cruiser sitting for a while and realized that I haven't started her for a while. Well apparently she didn't appreciate sitting for so long and I had a hell of a time starting her. Eventually she started but only after the battery just about went dead. I charged her up for around 20 mins and thought I'd turn her off and start it up again. Well to my disappointment, all I got was a click. I hooked up the cables in case I didn't get a charge but even after a jump, I only got a click. What gives? Starter go out? I can hear the solenoid engaging
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    19,933
    Media:
    17
    186
    Oct 1, 2003
    MN
    Fully charge your battery and verify that all battery cable connections/ground connections are secure and see what you get.....
  3. Weedhopper
    Weedhopper SILVER Star
    1,619
    362
    Mar 9, 2007
    HUH ? Oh..... CT
    If you do what Poser tells you and nothing happens give the starter motor a little love tap with a rubber mallet. That may jiggle something to get it to start, but also means it's time to get the starter rebuilt.
  4. Pighead
    Pighead Stop calling it an FJ SILVER Star
    7,413
    45
    Aug 31, 2004
    Walmart parking lot
    No, you did not burn out your starter. It takes a lot to burn out a LC starter. I've climbed hills using just the starter. I've gotten out of the middle of intersections using just the starter.
    Agree that a few love taps with something other than a BFH (I've used a shoe before) avoiding the solenoid, often restore a starters starting ability.
    Sometimes jumping a starter with a big screwdriver blade or wrench between the two big post will turn the starter when the ignition switch won't.
    Usually just a good, honest 13.5 DC volts will do it.
  5. Larr75fj40
    Larr75fj40
    365
    1
    Jan 12, 2007
    I tapped it and no response so I got a bigger hammer. I tapped it again and still nothing so I got a bigger hammer. I whacked it, it still doesn't work and I'm out of hammers! I removed it and took it to the neighborhood Kragen for a match replacement. To my amazement they had one! Brought it home, installed it and works like a charm. $57 bucks with a lifetime warranty including 2 years roadside assistance! Amazing!!!
  6. Fast Eddy
    Fast Eddy SILVER Star
    13,921
    1,355
    Apr 5, 2006
    Morgan Hill, CA
    What about offroadside assistance? :whoops:
  7. Larr75fj40
    Larr75fj40
    365
    1
    Jan 12, 2007
    Lol! You bring up a good point though, AAA won't help you if you're off the pavement.
