Dead alternator
Discussion in '80-Series Tech' started by NW-sickboy, Aug 28, 2003.
  1. NW-sickboy
    NW-sickboy
    701
    2
    Feb 5, 2003
    Eagle, ID
    So after doing lift. tires, brake lines and breathers, and thinking its smooth sailing and time for fun my alternator decides to go bad. oh well just more wrench time i guess.....any opinions on alternators. OEM, rebuild, mean grean, Any and all suggestions are welcome.......
    searched but didnt see an "Offfical alternator thread" just alot of this and that.
    so lets hear it what are you guys running.
  2. landtank
    landtank SILVER Star
    18,423
    596
    Mar 27, 2003
    Groveland MA
    Go down to the dealer and get a brush kit for the alternator. Has worked everytime for me and less than 10.00 from what I remember.
  3. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    Thans what di did once. Shouldn't you replace the bearings too?
    kurt
  4. landtank
    18,423
    596
    Mar 27, 2003
    Groveland MA
    From what I remember the bearings are pressed on and alot of work to get to. I've always just jammed in the new brushes and called it done. It's actually something I do as preventative maintenance somewhere after 100k.
  5. NW-sickboy
    NW-sickboy
    701
    2
    Feb 5, 2003
    Eagle, ID
    my rig has 134K (by the way its a 97) and i dont want to do just brushes (although) i wish the PO had done it at around 100K. any one else want to chime in.
  6. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    HOLDER ASSY, ALTERNATOR BRUSH (for 1FZ): 27370-75060, list $15.72
    ALTERNATOR, REMAN: 27060-66070-84, list $333.23 (exchange)
  7. landtank
    18,423
    596
    Mar 27, 2003
    Groveland MA
    NW-Sickboy, This week I'm in PA so I don't have a manual handy but there is a minimum brush length stated in the FSM that you could check. If it turns freely and they check out as needing replacement I'd gamble the 15.72.
  8. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Do they have 2 choices for alt brushes for the 80? plug in style and the solder in one.
  9. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Kurt,
    In the case of the 80, the brushes come already installed in the holder. So it's pretty easy.
  10. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I tried soldering the brushes in my HiLux. I suck at soldering.
  11. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Mike,
    I believe photoman is running the mean green alternator. You can wait for him to reply or do a search. As I recall he was kinda ho-hum about the mean green considering the cost.
    Another vote for the $15 gamble. The other $300 would go into the "Feed C-Dan's dogs" fund (aka the Supercharger lust fund)
    -B-
  12. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Mike,
    -B- is correct. I have the Mean Green alternator and starter. They work fine. The only questions in my mind were if they were any different than stock. Both are the same size as stock. I did not notice any difference in the cranking of the starter. I posted a question about how to test the output of the alternator and it seems there was not a good answer; so I can't say how much it is putting out. FWIW I only ran the cruiser for a month or so after the install and then parked it, so I can't even speak to the longevity. Sorry, not much help.
    Bill
  13. cary
    cary
    3,109
    21
    May 7, 2003
    I replace mine because the bearing was going south. I ended up using a Bosch rebuilt for about $240. I would recommend if you replace it to stay with factory or Bosch. All others seem to shortcut on the rebuilding process and go bad in a year or two.
    Cary
  14. DanKunz
    DanKunz
    8,855
    Media:
    2
    521
    Feb 7, 2002
    Woodstock, GA
    Man, I read this today and was curious because my charge gauge was sitting flat....sure enough...
    I lost my alternator on the way home (I think it was gone this morning).
    The battery was drained which implies it was dead for a while...I had a new red top in there that kept things going.
    I ordered (drum roll) a brand new OEM alternator from a dealer somewhere in the US.
    Got a sweet deal me thinks...even paid for next day Fed Ex (ouch!).
    I don't know if the 1991 alternator is the same as the later models...so I really don't know if I can compare.
    New alternator vs. brushes when it could be a voltage regulator = buy the farm and get piece of mind.
  15. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Dan,
    Did they ask you if you had an 80 or 90 amp ? Or ask for the number off of the old tag? It's most likely a 27060-61091-84 It could be a 27060-61100-84 (90 amp, rare) If it was the 27060-61091-84 I hope you didn't pay more than about 250 bucks for it, plus core. ;)
    Dan.
  16. DanKunz
    DanKunz
    8,855
    Media:
    2
    521
    Feb 7, 2002
    Woodstock, GA
    can let you know in the morning.
    I was in a pinch and had to order before fedex was done for the day.
    I ordered from a known parts department that has a 91 owner as a manager.
    I trust the price and the part info.
  17. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Cool....
    Just lookin' out for ya.. :)
  18. DanKunz
    DanKunz
    8,855
    Media:
    2
    521
    Feb 7, 2002
    Woodstock, GA
    you have me curious though...
    I will post the part number findings in the morning
  19. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    I'm sure Mr H. knows what he's doing. Never met the guy but know of him. Can you make out the tag on your current (get it?....current) alternator?
  20. DanKunz
    DanKunz
    8,855
    Media:
    2
    521
    Feb 7, 2002
    Woodstock, GA
    Will post that in the morning as well.
