Got back from a business trip last night and the LX was dead in the airport lot. Key fob would not open the doors, horn would not work etc. Been having some trouble with the fob and still not sure if it is the source of the issues. Ran jumper cables off of 2nd battery and when hooked to the positive the alarm started going off. Went ahead and used the fob to lock and unlock the doors, reset the alarm and still the truck would not start. It is the factory LX alarm system.
Went ahead and hooked up the cables again to the 2nd battery, jumped the truck and it started. Got to the house, shut the truck off and the ABS light, Seatbelt light, Park light and one heater selection light stays on. Put a charger on the battery last night, LX started up this morning but the same lights are continuing to stay on with the key pulled out of the ignition switch. I also unhooked the battery while charging to see if the ECU needed reset.
Scan guage is showing no codes and the volts coming off according to it is 14.2 or so.
Is this the "Christmas Tree Effect/ Bad Alternator" that I have seen on a few searches or am I chasing another problem? PO mentioned a slow battery drain but I thought the battery he had in it was no good and replaced it. Have not seen these lights on when the truck has been off until last night.
Thanks,
Pack Mule
Thanks,
Pack Mule
