So my old girl needs some suspension TLC.
The rubber bushings are shot all the way around,
and spring mounts have been modified by the PO. I am not overly impressed with the weld on riser setup that is going on and would love to get this done right!
I figured I would start with replacing the bushings and see if I had noticeable improvements in handling. When driving the truck follows every bump and I find myself constantly steering, even on straight stretches.
Dug into the first spring shackle/hanger and after removing the pin, there is no way I would reinstall it!
So...... thinking of taking advantage of this moment to correct some previous abuse..... cutting/grinding off the PO's spring mounts and properly welding in new.
New suspension kit - springs/shocks/bushings/steering dampener/U-bolts/extended nonreversing shackles with greasable bolts.
Possibly TRE's and draglink while Im at it.
Questions;
Am I missing anything?
When I removed the pin, the spring does not want to naturally line up with the shackle mounts. As if the mounts were welded to the wrong position? Or is this because I only have the one corner of the truck lifted and the front axle housing is torquing it?
I need some lift on this rig as I am running 33x12.5's... Not planning on much bigger. If spring mounts are welded more like original, what would I need for suspension/shackles?
Also no sway bar on this rig... should there be?
Best deals on good suspension parts can be found where??
Thanks in advance!
Craig
Questions;
Thanks in advance!
Craig
