FYI...Phoenix is starting to make adapters for the toyota r151. I'm planning on running the r151 w split tcase. I've been promised the one of the two prototype adapters....now if they would just hurry up and get them done. PM me if you want more info
Thread revival Talked with Phoenix Casting about a month ago and the are not going to make an adapter for the B3.3 to Toyota. Just have to stack adapters.
there is another way to do it if you're using the r151 and you don't have to source the elusive/expensive 1hz flywheel
hmmn...they did make them the had them this summer...did the not make any more. They were for a 1hz to h55 and 1hz to r151.
dodge bellhousing bolts up to r151...then use just use clutch parts for the dodge.
the ax15 and r151 trans are almost identical...if you google it there are a bunch of jeep forums with good info.
input shaft length is the same if you get a r151 out of a cruiser. If it comes from a mini truck it's the wrong length. I'm getting closer to this part of my build...I will post a build thread soon with some more details.
(i thought the R151 was a pickup turbo transmission, will have to research that).
