Cracked T-case repair?
Discussion in '40- & 55-Series Tech' started by Paul_A, Sep 9, 2003.
  1. Paul_A
    Paul_A
    186
    Apr 1, 2003
    Rosendale, NY
    I am rebuilding a '78 transfer case and now I find it has a hairline crack started at the top on both sides where you would expect it to be. It's about 1.5-2 inches long. I see the case saver plates. Has anyone tig welded a cracked case with any satisfaction? Weld inside and out? I hate to junk the case because of the money to replace. :-\
  2. 1Fine40
    1Fine40 Rust Buster SILVER Star
    780
    13
    Aug 25, 2003
    Wild Idaho
    I've known two guys who did just that (tig the case).....and ended up with the new "two piece" transfer case! :( It didn't hold up too long. The case saver is great for good cases, but already broken ones....not too sure on that. I wouldn't want to trust it if it was me...YMMV
  3. willsta2000
    willsta2000
    146
    Sep 26, 2002
    Yakima, WA
    I'd just spend the $30 and buy the saver. http://www.tcase.homestead.com/
    Bag the idea of welding the crack regardless, I would think you'd weaken the surrounding aluminum having it welded up, being it isn't very thick.
    I've seen empty cases go for maybe $30-50 on eBay from time to time, so you might want to check there also.
    If you've already gotten deep into the rebuild I would get a new case. I guess when they go, there's a very good chance your gears will get torn up in the process.
  4. woody
    woody Internet Fireman Staff Member
    10,331
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    IMO, you can weld it to be better than new...the alum bellhousing attaching my motor to my SM465 is welded....professionally. Basically, he drilled a hole at the end of the crack, cleaned the crack out and beveled it, then welded it from both sides. Stronger than stock. 5 years running of HARD use and no problems.
    I wouldn't try it myself tho...my alum skills aren't good enuf!
  5. dinkleberry
    dinkleberry
    303
    May 15, 2003
    Vermont
    Ditto to that. I used to work in a Hypo tranny shop and my boss used to weld bellhousings all the time. Never had one come back, and these trannys were run in bracket racers.
  6. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    I am a professional welder and woody is right. Done correctly, that case could be stronger than stock.
  7. Paul_A
    Paul_A
    186
    Apr 1, 2003
    Rosendale, NY
    And there is no issues that the case is a casting? I can TIG the case if there is a reasonable chance of it holding.
  8. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    If done properly, no prob. I'm not at my shop and I can't remember the rod number off the top of my head. Look it up and get the right rod for cast alum. If you aren't a good welder , do not attempt to learn on used Aluminum. Very porous and holds a lot of oil.
