Course or fine spline birf. for a 77' fj
Discussion in '40- & 55-Series Tech' started by Guest, Mar 17, 2003.
  1. Guest
    Guest Guest
    Do i need a course or fine spline birf. for my 77' fj40?
    Thanks
  2. Trevor
    Trevor
    883
    1
    Mar 11, 2002
    fine, assuming it's stock.
  3. woody
    woody Internet Fireman Staff Member
    10,332
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    disc brakes, fine spline....and 76-78 were a slightly different birfield than the 79+/minitruck style. 76-78 have a slightly smaller bell diameter and a slightly longer shaft. 79+ birfs work, but you'll need to grind inside the knuckle a tad for the bell to fit and run a bolt/fender washer to hold it in the lockout instead of the c-clip at the end.
    IMO, you should do the mod anyways since the 76-78 birfs are much more rare than the 79-91 birfs used on FJ40-55-60-62 and minitrucks (which are ALL the same, at least in the USA....)
