converting fj60 power steering to mini
Discussion in '60-Series Wagons' started by HighToy, Jan 22, 2003.
  1. HighToy
    HighToy
    2
    Jan 22, 2003
    I am picking up a toy minitruck power steering setup tonight to convert the combo setup to the remote setup. I haven't been able to find any info on this yet and was curious if anyone has done this conversion and what was involved.
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,090
    Jan 15, 2002
    Toquerville UT
    brain dead me...on a 40 series? 60 series?
    <--clueless, and late in the work day.....
  3. rick_d
    rick_d
    1,298
    97
    Apr 20, 2002
    FJ60?
    I hate to sound repetitive, but I am a firm believer in a new Toyota PS pump vs anything else. $330 delivered is the best money spent on an item that should last 10+ years as the very first pump off the assembly line did (use a filter, use dextron III, and flush the system 100%). OH of a used pump can meet with success if a low mileage one, but if high mileage the tolerances are blown and no kit will resolve. Reman'd pumps same deal. I turn in terrible calipers for reconditioning and I would expect same for PS pump cores. Every remanufactured FJ60 pump I have ever seen leaked, period.
    Using some ? mini truck pump or saginaw is a waste of time. effort etc. If you have a pre 1979 block, then an alternate is a must (as a FJ60 - late FJ40 bracket won't fit).
    my $5 advice.
  4. Man Jerk
    Man Jerk
    2,107
    3
    Jun 28, 2002
    Colorado Springs, CO
    If I remember correctly, there is a pretty good reason for using the mini truck pump/resevoir. On an FJ60, the pump is bracketed to that tractor motor, and the resevoir is connected to the pump via a seal, whereas the mini has a remote resevoir. All the vibrations from the motor transmitted through the pump causes this seal to fail, then you've got a mess. I believe the mini truck pump is basically the same, it mounts up. And the resevoir can be mounted to the firewall avoiding sed problems. While I have no technical advise, I'll leave what I know. Go to a bone yard. Find a mini, and grab the pump/resevoir. Use the pump as a core for a reman, and mount away. How exactly..... ???
    I don't really know.
    If you find out tho, let me know. :D
  5. rick_d
    rick_d
    1,298
    97
    Apr 20, 2002
    2F's, 3F's, 3B's, 2H's all use reservoirs mated to PS pumps (belt drive).
    HZ's, HD's, KZ's, FZ's are a gear driven pump and space does not allow a reservoir near them-but they are engine mounted
    Diesel vibrate much more than a gas engine so I don't really believe that scenario.
    (only the F's above are gas, all are heavy duty land cruisers)
  6. Guest
    Guest Guest
    I think that's where mine is leaking, at the connection between the reservoir and the pump. Is it difficult to replace that o-ring or seal?
  7. toyofj60
    toyofj60
    390
    Media:
    70
    13
    Apr 4, 2011
    nc
    what ever happened with this????
