Isnt that what the owner of the FJ70 in Bolivia did with his 14B? I think he had to grind the webbing off on the inside to fit the bigger 14B clutch
I jumped the gun a bit there. What i should've said was its 'easier' if you use the 70 series alloy bellhousing. The earlier cast iron bellhousing can be used, but as Rosco points out, the webbing/ribs inside the housing will need to be ground down for clearance.
I think the 3F to 14BT swap write up mentions this.
