Code 28?
Discussion in '80-Series Tech' started by TrpD345, Jul 16, 2003.
  1. TrpD345
    TrpD345
    13
    Jun 10, 2003
    What is code 28 for the check engine light on a '94 LC? Thanks!
  2. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    #2 oxygen sensor sensor signal. Check with Toyota to see if has been replaced once from the oxygen sensor recall. If it has, then you need a new sensor.
    kurt
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Kurt,
    He needs a new sensor regardless. If the campaign has not been done, mr "T" will pick up the tab. It it has, Trp gets to treat. The campaign replaces both sensors. I would replace both regardless of who is paying the bill. The sensors can be purchased individually or in a "kit" containing both.
    Loose: 89465-69115 and 89465-69125, list $120.50 EACH.
    Kit: 89465-60110, list $220.03 for both.
    As you can see it's a bit cheaper to get the kit.
    Cheers, Dan.
  4. TrpD345
    TrpD345
    13
    Jun 10, 2003
    How do I know if Toyota has replacced it already? Thanks for the help!
  5. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    PM your vin to me and I will "run" it for you and find out. :D
  6. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    My oxygen sensor code on my Toyota Previa keep popping up every month or so, I would just reset the computer. This was my second Previa and wondered why it didn't have the power that the other one did?? After a year, the CE light stayed on and I replaced the oxygen sensor. WOW it was like adding a super charger to it! I then sold it.
    On one of those car shows, they said that you should change the oxygen sensor as you would the spark plugs but didn't say how often. He was talking about the Camry at that time. He said that oxygen sensors start to go bad before they send a bad signal to computer.
    So if your power is not what it use to be, maybe its the oxygen sensor. We 94 people had ours changed for free, at least the frist time. I don't know how long they should last on the 80??
    kurt
