Clutch problems BJ42
Discussion in '40- & 55-Series Tech' started by bj42turbo, Jul 18, 2003.
  1. bj42turbo
    bj42turbo
    369
    1
    Sep 8, 2002
    Victoria, Australia
    I have a 1981 BJ42 and a couple months ago I replaced the clutch slave cylinder all has being well untill today, When i release the clutch pedal it dosn't seem to come all the way up, like before when i was losing fluid through the faulty slave cylinder, I checked for leaks and i have lost no fluid. I love my truck but every time i replace or fix something, something else allways seems to happen, I guess this is part of the attraction.
    Dazz
  2. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
    i know the feeling, my trucks are both coming apart faster than i can put them back together.
    few things to check.
    spring from top of clutch pedal to a pin up under the dash...
    did u bleed the system properly the first time, have you tried to bleed it again to make sure. happened to me first time i changed my clutch master, clutch dissapeared in the middle of traffic.
    could need freeplay adjustment at the pedal, or at the slave. on both (i think) there's a locking nut, unlock then turn the rod (going throught the firewall on the clutch) or the rod on the slave.
    any1 else got any better ideas?
  3. bj42turbo
    bj42turbo
    369
    1
    Sep 8, 2002
    Victoria, Australia
    Yeh someone on another mentioned bleeding the system again which i have done today and it seems ok so far, crossing my fingers
    Dazz
  4. bad_religion_au
    bad_religion_au
    2,212
    Apr 24, 2003
