clutch problem??
Discussion in '40- & 55-Series Tech' started by Whipinfast, Apr 18, 2003.
  1. Whipinfast
    Whipinfast
    37
    Feb 19, 2003
    Basalt, CO
    '76 40 w/ 350.
    My clutch pedal had been gradually getting softer and softer with bairly any accual clutch movement. This morning there was no clutch movement at all, just the pedal. I bleed the system, still no pressure. Any ideas? :dunno:
  2. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    Was there any hydraulic fluid dripping from the seal around the slave cyl ? If yes, rebuild or replace. If no, rebuild or replace clutch master cyl.
  3. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Yes I would agree with toddslater.But Iwould rebuild both clutch slave and clutch master and then you know the hydro system is fine hope this helps :G
  4. fj40crusher
    fj40crusher
    463
    4
    Nov 7, 2002
    Pacific NorthWest
    I would replace the whole system. It's pretty reasonable. I have used the rebuild kits for the slave before...waste of money. It only lasted about 3 months and I was stranded again. You can replace the slave and master for about $100, that should solve your issue.
  5. Whipinfast
    Whipinfast
    37
    Feb 19, 2003
    Basalt, CO
    Thanks for the help guys. I think I am going to go ahead and replace the entire system.
    Thanks again :beer:
  6. toddslater
    1,498
    2
    Oct 31, 2002
    Kennett Square
    fj40crusher,
    did you give them a good and proper honing on the when you rebuilt ? So far I haven't had any probs with mine.
