clutch/overdrive
Discussion in '40- & 55-Series Tech' started by wayne_fj40, Feb 25, 2003.
  1. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Yes the po had put an overdrive unit in and I don't think he got to use It and I have no instuctions on It so I'm assuming it's In right but I don't know,and I'm wondering ifthat is why my clutch won't work I pulled the engine and installed It and pulled it again tonight I've pulled the bastard out more in a couple of days then most cars ever,the unit goes on the back anyone with any ideas I'm running out quick :mad: :mad: :mad: :mad:
  2. Erics75
    Erics75
    81
    Jun 14, 2002
    Can you elaborate a little, what exactly is it not doing, enguaging, disenguaging, slipping etc.
  3. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    Also what overdrive?
  4. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Ihave not looked to see what brand of overdrive I no the bastard bolts on the back.The clutch is engaged all the time when you push the pedal while its in gear makes no difference
  5. Pin_Head
    Pin_Head
    13,750
    1,318
    Feb 6, 2002
    OC, CA
    If you can't feel any resistance in the clutch pedal throughout its stroke, you have a problem with the hydraulic linkage that needs to be fixed first.
    If you feel ressitance at the bottom of the pedal, but the clutch doesn't release, you need to adjust the clutch linkage by lengthening the rod between the slave cylinder and the fork.
  6. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Oh yea there is pedal restance and Iv'e adjusted the rod so I have about a 1/4" free play at the tranny. I'm about to fly woody up to washington and have him look at it Ive put in a lot of clutchs and this is the worst thats why now I'm thinking they hooked up the od wrong I just don't know thanks pinhead
  7. woody
    woody Internet Fireman Staff Member
    10,335
    Media:
    303
    1,095
    Jan 15, 2002
    Toquerville UT
    1/4" is too much play....should be tighter IMO...also make sure you have a return spring on the clutch arm or it may not reseat the slave cylinder plunger all the way. Bleed/rebleed the hydraulic lines...might even flush to ensure no air or water in them. Check play at the master cylinder side too, should start to push fluid almost immediately. Check for fluid leaks on both sides of the firewall, sign of bad master (wet toes - lol).
  8. OswaldtheBold
    OswaldtheBold
    137
    1
    Jan 8, 2003
    I had a similar problem once. It seemed like the clutch stayed engaged, but everything seemed to be working OK. There was some rust on the transmission input shaft splines, and the clutch wouldn't slide on them enough to slip. Pull the inspection cover off the bottom of the bell housing, and have someone push in the clutch pedal while you watch it from underneath (engine off!) That way you can see if the throwout bearing contacts the pressure plate fingers, and if the clutch disk moves. The other problem could be a seized pilot bearing in the crankshaft. That would keep the trans input shaft from spinning freely from the crank.
