I have adjusted my clutch where the hydraulic thing wth threaded rod pushes against the arm connected to clutch under the truck. It is set at the furthest out position possible. I set it there trying to overcome a general difficulty getting it into gear... will go into gear easy with engine off but running requires a bit of effort. Since this is adjusted at the end of its travel I'm guessing something needs replacing. When you've reached the end of that threaded rod what's the next step?
Thanks, ChuckD
Thanks, ChuckD
